Dome light fix try killed dome, radio and clock power
I've had a non-functioning dome light for years now. Finally started troubleshooting and verified +12V at connector to dome assembly and bad assembly rivets/solder contacts. New assembly was working until my meter probe raked across + and gnd terminals that the connector goes into. Now I only get 0.3V and the radio/clock/enviro panel light are not getting power. Have checked all fuses in interior box. Dome fuse has +12 at the terminal but the connector at the top of the box that has the two wires (b-w and b) going to the dome light that used to read 12V now has only the 0.3V. Any thoughts as to what I zapped?
a
1993 3VZ-E Pickup
a
1993 3VZ-E Pickup
Staff
Most years the light circuit goes thru the door chime box located just above the steering column. If it is disconnected or removed, the light will not operate from the drivers side but will operate on the passenger side. The box I am talking about is for the years 92ish and older, not sure if 93 uses the box or not. Might want to check that box and see if it is shorted out or something similar.
a
admiralnahohkta
03-01-2020 01:44 PM
87runnerhawaii
06-08-2016 12:02 PM
MudWaspSR5
03-08-2016 03:11 PM
