Differences between 96 t100 harness and 97?
Just wanted to know if there are any big difference between a 96 to 97 harness. The reason i ask is im currently in the process of swapping over a 96 5vz and looking to supercharge it. Found out that the 96 ecu does recognize the boost and heard that the 97 will work fine just may give off a check engine light.
It just depends what you call big differences
T100 I am sure the T100 curse will be involved in some way.
If you change every thing so the engine is now a T100 engine it will be easier
This is something you need to sit down look at the EWD`s from both years your going to need to get the4th ECM plug and wire this more then likely.
I am guessing the ECM plugs will be different between the years
I don`t have the T100 EWD`s to double check .
I T100 was enough I still have nightmares !!
