| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Cruise Control
#2 (permalink) |
I would think that it is more likely a vacuum leak that is preventing your cruise from working. Check the condition of the hoses going to the actuator, under the hood.
If the hoses are good, then I'd start looking at the electrical parts - fuse, relay, switches, cruise module, ect. If you don't already have a Factory Service Manual, now would be a good time to get one - they are a lifesaver for diagnosing problems.
__________________
Raj : 1960 Homo Sapien. 192cm, Blonde, Blue. Soon to lose spare tire. Worf : 1990 SR5 Xtracab 4x4 5 speed, Inca Red Metallic. 3.4 converted, with Taco 5 spoke alloys, 275/65R16 BFG AT K/Os. Soon to add rear e-locker. |
#3 (permalink) |
Yep, clutch switch then vacuum, then check the ground connection, mine was down next the the CC module at the main cab ground point. Make sure the connector is on solid and if that is all OK, check the troubleshooting procedures in a Factory Service Manual.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club |
#4 (permalink) |
I do have the original service manual. Hopefully I'll find the problem thanks. Do you know if 93's have a cruse indicator light?
#5 (permalink) |
There should be one in the lower part of the cluster guage, under the speedometer. It should come on when you hit the cruise switch on the steering wheel.
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Cruise Control | PeanutRanger | 86-95 Trucks & 4Runners | 2 | 08-19-2006 09:10 AM |
| Cruise Control | kev93p-up | Maintenance & Repair Archives | 5 | 10-08-2005 03:52 PM |
| Cruise Control Help | colsoncj | 95.5-2004 Tacomas & 96-2002 4Runners | 15 | 06-20-2004 09:31 PM |
| Cruise Control | Churnd | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 03-19-2004 03:51 AM |
| cruise control | Krazxyglue12 | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 01-03-2004 01:59 AM |
