changed out driver signal lights - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > General Electrical & Lighting Related Topics
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-20-2009, 07:09 PM   #1 (permalink)
jesseunvoas's Avatar
i just bought this truck two weeks ago and i had to change out the rear signal light so i figured i might as well do all the bulbs since i had LED's in my 82 pickup and everything seemed fine until the front signal light. what would happen is when i turn the right way to signal it does the flash faster like in my other truck as if i had a burnt out bulb but on the driver side as soon as i changed the bulb out the flasher would stay on always and not flash. so has anyone ever come across this problem. I can't send my truck in to be safetied until this issue is resolved so any help is appreciated.
jesseunvoas is offline
Old 10-24-2009, 10:21 AM   #2 (permalink)
i guess what my problem was, was that when i put in LED bulbs there wasn't enough resistance and then it would just stay on all the time i guess i will have to find out what resistor i need to put in line to even out the current
Old 10-24-2009, 10:37 AM   #3 (permalink)
4Crawler's Avatar
6 ohm, 50 watt resistor, one per side is what you need. I have a pair I wired up to a 4-pin trailer wiring socket that I had installed on my '85. No longer need it but if you have a trailer wiring plug, this would plug right in.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 10-24-2009, 05:49 PM   #4 (permalink)
thanks i will pick some up at the electronics supplier when i have a chance
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
