YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > General Electrical & Lighting Related Topics
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 08-12-2008, 06:06 PM   #1 (permalink)
GSGALLANT's Avatar
In cab control for Warn M8000 Winch
When trying to wire an in cab switch for my Warn M8000, I did some searches to get some ideas, and noticed that there were not a lot of wiring diagrams available out there, so I decided to put one together.
As part of my design, I wanted to have a master kill switch for the winch mounted inside the 4Runner for two reasons. First reason being that my winch control box (solenoid box) is mounted on top of my bumper, and I wanted to have a kill switch to prevent anybody from tampering with the winch with a paperclip or piece of wire. Second, I have a young child, and he likes to play with buttons, so if I was going to have in cab controls, I wanted to have a sure fire way to ensure that he wasn't going to be playing with the winch. That is why I chose a master switch that locks with a key (basically works like an ignition switch.)
I also wanted an indicating light that would let me know that the winch is armed. I mounted the kill switch, indicating light, and DPDT momentary switch below the truck's ignition switch. (You need to use a DPDT switch to properly control the winch from the cab if you have a winch that is controled with a five wire remote).
This isn't meant to be a detailed writeup of where I routed wires and such, but here is the wiring diagram for you guys in case somebody else is looking for the same setup. I'll try to snap some pictures of the location I chose for the switches and the indicating lamp at some point this week.
Note: In the image below, the connections to the brown, green and black wires are shown as being on the wire of the remote control (downstream of the remote connector), but they are actually made inside the winch control box (upstream of the remote connector). This is just because there was not enough room on the drawing to show all the connections upstream of the connector (on the left side of the five "double arrows" on the drawing).
__________________
2002 4Runner, Auto-A340F, 3.4L, 4.30 Gears
TJM T15 Front Bumper & Warn M8000, 4xInnovation sliders, Sonoran Steel 1.2 Lift, Toytec LCA Skids, Tundra Brake Upgrade (231mm), Extended rear diff breather, Deckplate Mod, Andymod, Dual batt setup with Optima blue top aux battery, Hardwired 1000W inverter, Aux fuse box, Full time power to 12V plugs, Yaesu FT7800R Radio, "4-air" system for airing up/down tires.
2004 Camry LE - stock (and will stay that way)
1993 4Runner has been sold
GSGALLANT is offline
Sponsored Links
To remove this ad, register today!
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Warn m8000 Winch wired up right? Scooby098 Newbie Tech Section 3 02-06-2008 12:04 PM
Warn M8000 Winch $505 Shipped! HiLuxer Hot Deals/Free Stuff 1 11-12-2007 01:21 PM
M8000 Warn Winch(but older model) Spark-e3 Offroad Tech 4 12-03-2005 03:51 AM
Max cable length for warn M8000 winch? Tenkom Offroad Tech 9 12-07-2003 02:29 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
