| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
bulb wattage
#2 (permalink) |
I have 100 watt bulbs in my Hella 500's and 500ff's, work great for me....never had a problem. I don't have any experience with the 130 watt bulbs though.
__________________
2006 Tacoma SR5 - Stock for now 2000 4Runner Limited 16x8 Pro Comp Steelies wrapped in 285/75R16 Pro Comp M/T'S~RB 2" Body Lift~SS 1.2 Lift~Rear Locker Mod~Surco Safari Rack~ Trail Gear Sliders~Deckplate Mod w/ True Flow~Satoshi Grille~Hayden 1678 Aux Cooler~Safari Snorkel and a bunch of other crap..... |
#3 (permalink) |
i got 100w bulbs in my 700ff's no problems yet just make sure to run at least 12ga wire
#4 (permalink) |
x2 I ran everything with 12ga wire as well
__________________
#5 (permalink) |
i think i've decided to run 100s in all four lights. now when i go to wire them up, im using 12g wire but what amp fuse should i run? all four lights are going to be on one switch.
#6 (permalink) |
40amp. I might upgrade the power/ground wires to 10 guage if you're runn that many lights off one wire..
__________________
91 Pickup - xcab - 5sp - 3.0 - SR5 - 4x4 - 233,000kms |2.25" catback w/ magnaflow cat + glasspack | Weasy2k cams | Aisin manual hubs | Diff breather mod| Marlin HD clutch |3" BL | es3000's |2" AAL |1.5" bj spacers | ISR | Alpine headunit | 4" Infinity fronts/5" rears | 4.88's |Rear lockright | 33x12.50" BFG M/T on 15x8" steelies |Hella 500's |4" reverse lights| Grant GT |Downey idler arm brace|hella E-codes| Marlin armor | %100 Amsoil synthetic http://www.cardomain.com/ride/2572486 |
#7 (permalink) |
ok i think im going to run two relays, one for a set of 2 lights. simply cause this is going to be a lot of watts for one little switch. is there a diagram showing how to wire two relays together? also, will two 30 amp relays do the trick?
#8 (permalink) |
two 30amp relays will be fine to run both of them just run the trigger wire off the switch to the relays
#9 (permalink) |
Yep. That will work just fine.
__________________
#10 (permalink) |
can someone draw up somethin in paint for me? showing where the four terminals go to on each relay? thanks!
#11 (permalink) |
here you go
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| hella 500's...any wattage? | 89red4x4yota | General Electrical & Lighting Related Topics | 7 | 02-11-2007 08:28 PM |
| Higher wattage 94 4runner 9004s | L33T35T 4Runner | General Electrical & Lighting Related Topics | 12 | 12-15-2006 06:08 PM |
| Glove box bulb dead, changed bulb, checked fuse, still SOL | Dug | 95.5-2004 Tacomas & 96-2002 4Runners | 6 | 11-06-2006 09:41 PM |
| Help finding wattage of amp | Mac6135 | Vehicle Audio & Home Entertainment | 11 | 09-01-2006 12:16 PM |
