YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > General Electrical & Lighting Related Topics
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 08-11-2008, 01:30 PM   #1 (permalink)
99SR5's Avatar
Send a message via AIM to 99SR5
blown fog lights
so i blew my fog lights one day when i was wheelin and they dont work now. i replaced the bulbs and that didnt do it. not sure if the fuse would be blown, what would you guys recommend i check? do you think the whole assembly and such should be replaced?
__________________
87 4Runner SR5
- some spacer lift with cranked torsion bars
- generic 31/10.50 all terrains,
99 4Runner SR5 Highlander-auto
- K&N filter, removed intake elbow, open air box, deckplate mod
- 265/75/R16 BFG MT's on stock 5 star's
- raised rear diff breather
2003 Mach 1
-full bolt ons, 4.10 gears, un tuned.
99SR5 is offline
Sponsored Links
To remove this ad, register today!
Old 08-11-2008, 01:32 PM   #2 (permalink)
Check the connections.
Not sure about it, but maybe the switch assembly in the steering column is out.
__________________
1990 4runner SR5, 3.0 with 254K, 5-speed, 4.56 gears, , Rancho 9000's, 33X12.50's trxus mt's, rear lock right, 4" lift with lc coils in rear
Quote:
Originally Posted by 4rnr View Post
I have NOOO $$ Im a poor college kid I recently started working so I decided to SAS.
If I dont sas Ill just waste money on chili cheese dogs and beer then Ill be poor, fat, and STILL on ifs.
My build thread
http://www.yotatech.com/f152/904_run...thread-158746/
904_runner is offline
Old 08-11-2008, 07:16 PM   #3 (permalink)
99SR5's Avatar
it could be switch problem but it happened after i went through deep water so im thinkin i blew something.
__________________
87 4Runner SR5
2003 Mach 1
99SR5 is offline
Old 08-11-2008, 07:28 PM   #4 (permalink)
jason191918's Avatar
Send a message via ICQ to jason191918 Send a message via AIM to jason191918 Send a message via MSN to jason191918 Send a message via Yahoo to jason191918
If you went through water, you shorted the circuit and blew a fuse.
__________________
JASON
1992 Pickup V6, 4x4, 5 speed, SR5, 300,000 miles young, every option except automatic tranny
31x10.5R15 | K&N FIPK | Cherry Bomb | 3" BL | 4 110W KC Light Bar | 6'6" Western Plow | 800W 10" Sony | 850W Sound Storm | 2 4" Obcon | 4 1" Rockford Fosgate Tweeters | 2 High Pass Crossovers | 2 High-Low Pass Crossovers | 2 6.5" Rockford Fosgate | Pioneer 4x50W Head Unit | Mechanical Oil Pressure Gage | Lack of EGR
Quote:
Originally Posted by Elvota View Post
Jason is right.
Quote:
Originally Posted by fishon1213 View Post
Jason rocks!!! :banger:
jason191918 is offline
Old 08-13-2008, 08:14 PM   #5 (permalink)
99SR5's Avatar
thats what i thought. is there a fuse and a relay or what? cause i found the relay in the engine compartment. im guessing the fuse would be under the steering wheel? and should i just replace both the relay and fuse or just fuse?
__________________
87 4Runner SR5
2003 Mach 1
99SR5 is offline
Old 08-13-2008, 08:50 PM   #6 (permalink)
No sense replacing what isn't broke. I would suspect the fuse. Easy as cake to check/replace. If that doesn't do it try the relay, but I doubt that is the problem.
__________________
JASON
Jason is right.
Old 08-15-2008, 01:38 PM   #7 (permalink)
99SR5's Avatar
so i had my boss look at it and the fuse and relay were fine so he looked at the connections on the fog light itself and tunes out it was the wires and connections were filthy. he cleaned it up, got rid of that metal thing that looks like a bridge, and used two washers are the ground and connection
__________________
87 4Runner SR5
2003 Mach 1
99SR5 is offline
Old 08-15-2008, 02:22 PM   #8 (permalink)
Did it work after?
__________________
My build thread
Old 08-22-2008, 11:14 AM   #9 (permalink)
99SR5's Avatar
yep works now. and i love it. its been about two years since they worked.
__________________
87 4Runner SR5
2003 Mach 1
99SR5 is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Raybrig Fog Lights Jdm Crx Eg Ek Ef Led ~ Must See ~ Fog & Led Lights In Same Housing CDUFF7 Misc Stuff (Vehicle Related) 1 07-07-2008 06:00 AM
Wiring Question - Fog Lights and Parking Lights zach34 95.5-2004 Tacomas & 96-2002 4Runners 12 08-26-2004 11:48 PM
Driving lights vs fog lights Hella 500 ElwayLite 95.5-2004 Tacomas & 96-2002 4Runners 4 02-21-2004 08:48 AM
Fog Lights & Daytime Running Lights cybrenergy 95.5-2004 Tacomas & 96-2002 4Runners 27 10-02-2002 06:08 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
