YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > General Electrical & Lighting Related Topics
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 08-11-2008, 08:54 AM   #1 (permalink)
Kinked's Avatar
Blowing Fuses in 79 BJ40
Hi,
Trying to get a 79 bj 40 with 42 parts up and running. it runs fine however something with the lights is messed. the headlights work, but when the turnsignals are used it blows all the light related fuses...
hopefully someone can help figure this out..
thanks in advance
__________________
91 4Runner.... Alpine IDA-X001 Head Unit, Alpine 4" Front Spkrs, Alpine 5 1/4" rear Spkrs
92 S-10 Blazer.... might SAS it... maybe
Kinked is offline
Sponsored Links
To remove this ad, register today!
Old 08-11-2008, 10:10 AM   #2 (permalink)
4Crawler's Avatar
Pull all the turn signal bulbs and see if the problem goes away. If so, replace a bulb at a time and re-test. If no bulbs still blows a fuse, remove all bulbs and re-test. If problem remains, try disconnecting parts of the wiring harness until it works then replace items until the short returns.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs.
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
fuses blowing nomiss05 84-85 Trucks & 4Runners 0 05-08-2008 08:52 AM
keeps blowing fuses ryanflknr 86-95 Trucks & 4Runners 3 01-03-2008 08:50 PM
Blowing Fuses??? fierohink 86-95 Trucks & 4Runners 6 03-30-2007 02:47 PM
Blowing Fuses?? Renegades 95.5-2004 Tacomas & 96-2002 4Runners 4 12-02-2005 04:57 AM
Keeps blowing fuses husker267 95.5-2004 Tacomas & 96-2002 4Runners 4 08-23-2005 11:59 AM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
