| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
BIG 3 wire upgrade?
__________________
Only in a YOTA, cause the force is with you. 92 4runner, 3.0, 5sp K&N FIPK |
#2 (permalink) |
It involves using a 3" solid core copper positive battery cable. They're very hard to find these days and cost about $800/foot to purchase.
Good luck. ![]() Just kidding... Big 3 refers to upgrading the wire gauge sizes of the main 3 wires in the electrical system. 1) Battery negative to chassis 2) Alternator to battery positive 3) Chassis to engine Btw, I'm really surprised that the search you did came up with nothing on this... Maybe try google after you search yotatech.
__________________
'95 xcab - SOLD '03 4runner V8 SR5 completely stock Last edited by ovrrdrive; 09-28-2006 at 03:44 AM. |
#3 (permalink) |
__________________
'95 xcab - SOLD '03 4runner V8 SR5 completely stock |
#4 (permalink) |
Thanks for the link, but i was looking for some thing more 2nd gen 4runner.
__________________
#5 (permalink) |
Same concept. Heavey gauge wiring between battery negative and chassis, alternator and battery positive terminal, and ground between engine & chassis.
__________________
TNRabbit Stock '94 DLX XtraCab 4x4 5 spd, Newly Rebuilt 3VZE, 17" 2006 Alloy Wheels, 228k miles, AISIN Hub Swap 3.0 Rebuild Thread: http://www.yotatech.com/f116/crap-he...-ghost-108156/ |
#6 (permalink) | |
Quote:
#1 is easy, just a little short wire in plain view that screws to the body on the inner fender. Take the time to clean the body sheet metal with some sand paper. #2 is the hardest on our trucks because the battery & fuse box is on the other side of the engine bay from the alternator and the wire goes from the alt to the fuse box then to the battery. I took the fuse box apart so I could connect the parallel wire directly to the same connection points as the stock wire. Make sure you route this (+) wire where it won't get cut or damaged and protect it well with split loom. Remember (+) wires that get cut and grounded on something can start big fires! To the alt: I almost forgot if you upgrade the battery to the fuse box wire you must keep the fuseable link that is right off the battery (it is the smaller section of wire about 4-6 inches long). If you add a second wire parallel it also must have a fuseable link (This was one place I upgraded the existing wire rather than adding a parallel wire. (not sure how safe it is to add another fuseable link). This is what my fuse box looks like after the upgrade, I used 4 gauge from the fusebox to fuseable link and the fuseable link is connected directly to the battery: #3 Bolts to the block (probably very dirty so clean up the contact surface) and runs to the battery (-).
__________________
~Dale~ 93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000. Last edited by mt_goat; 09-28-2006 at 06:13 AM. |
#7 (permalink) |
Would there be anything wrong with running a wire (2ga) from the alt to the battery with a say 125amp fuseable like (100 amp alternator), and just leaving the stock setup? I am not worried about anything drawing more than the OEM wiring can handle, except what is atteched to the battery directly.
__________________
-John '05 Dodge 3500 SRW 4x4 SLT 5.9 Cummins QC LB NV5600 2003 SR5 4Runner, V6 4WD. 1" cornfed lift Previous Toyota's '92 Red Truck NALA Speed doesn't kill, its the sudden stop that hurts. |
#8 (permalink) |
AH62ID - nope, no issues atall. My 1/0 run from the alt to battery is unfused actually...
What helps everything a lot is grounding redundancy. I have 2 grounds to the chassis, one at the OEM location and one behind the charcoal canister on the fire wall. I have 2 grounds to the engine, one to the block and one to the head. The last set of groud that I havent done are going to be from the frame rails to the block and to the battery. And while im in there im replacing the OEM wire that feeds the fuse box with a nice fat 1/0 if itll fit...
__________________
3vze, 4x4, sr5, 90, auto, LSD 2x dB Drag World Finalist 2003 Nopi Nat. Street B champ 2004 SBN Street C champ 2004 SBN Advncd NW Champ 2004 Former WR Holder in NW. SPL: 159.8db @ 42hz In loving memory of Jamie Riggs 5/15/85 - 10/8/04 |
#9 (permalink) | |
Quote:
With the engine out I plan to beef up the chasis ground, and then block ground. I alreay have a huge frame ground. When I wired my winch I ran cut the ground in half and bolted it together with one of the bolts holding my ARB on, so I think its grounded well enough.. As far as the alt wire, I figured that was safe.. but none the less I will probally acquire a 125 fusable link just to be safe. It should really help when winching. I had my OEM alternator rebuilt with a toyota 100 amp winding, then put a smaller pulley on it so it puts out max amps at about 1500rpm. The only issue I have is it still goes offline at about 700rpm. I havent figured it out yet since the guy who built it said it should be putting out about 35-40 amps at that speed, must be part of the OEM voltage regulator.. .I wonder if there is any way to fix that....
__________________
#10 (permalink) | |
Quote:
__________________
~Dale~ 93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000. |
#11 (permalink) |
The fuse sounds like a good idea to me, if you do connect the alt straight to the battery. In a perfect world you wouldn't need any fuses, but happens.
__________________
~Dale~ 93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000. Last edited by mt_goat; 09-28-2006 at 08:04 AM. |
#12 (permalink) | |
Quote:
The guy who did it does all the the rebuilds on alternators and starters for my dads boat business. He does good work, just doesnt work on too many toyotas
__________________
#13 (permalink) |
I found the 4 gauge to be a pretty tight fit in the fuse box openning. Bigger and you may have some extra work. IIRC the stock was about 8 gauge so going to 4 gauge is a pretty big upgrade (looks to be about double the OEM wire to me)
__________________
#14 (permalink) |
this is true and you are correct I should have fused my alt to battery line.
__________________
#15 (permalink) |
Cool this helps alot thanks guys.
__________________
#16 (permalink) | |
Quote:
__________________
#17 (permalink) |
wow the peeps on that site LOVE the 3.0 I see. Too bad they dont realize the 5vzfe has just as big a HG recall as the 3vze...lol
The alternator generates current as the electrical system needs it. Voltage is the best indicator of whats going on in your electrical system. You probably never saw that much current in the truck at idle but your voltage was probably at least 13.0v or so....which means it's workin fine!
__________________
#18 (permalink) | |
Quote:
__________________
#19 (permalink) |
ah thats normal, my 190 amp unit used to not turn on until about 1100rpm...
In your case though you can just bump the idle up to 800 and not worry about it!
__________________
#20 (permalink) |
What I thought was odd was I put a much smaller pulley on it and nothing changed.... so what causes that? Why will it put power at idle rpm on the bench, but not in the rig?
__________________
#21 (permalink) |
So the positive battery cable has that break off wire that goes to the slow-blow fuse. That wire from the fuse goes to the alternator??? There was another post from long ago that I found in a search that talked about that wire going bad and maybe being a little small and showing how to upgrade it. I think I posted a link to the starter of this thread on his other thread, but if what I am putting together from that other post and this post. That is the wire that the alternator connects to the positive battery cable. My battery light comes on where there is no charge going to the battery and then a little while later it will go off. This could be the issue for me. I will have to upgrade all four of the wires to be sure. If I am right, we should change it to the big 4 wires.
1. + Battery to Slow-Blow fuse 2. Slow-Blow fuse to Alt. 3. - Battery to chassis 4. Engine to chassis Thanks for the insight. siris
#22 (permalink) | |
Quote:
If you dont mind me asking, with what parts did you rebuild the alt?
__________________
-- My 2 cents = 1 Peso 1987 4Runner Operation: Nostalgic! in effect |
#23 (permalink) |
I dont have a clue, the guy who rebilt it said he found toyota parts to beef it up.
__________________
#24 (permalink) |
A few notes:
1) You shouldn't parallel fuses/fusable links of X amps. Current travels through both paths and assuming you just added another fuse of X amps, the net result is putting 40 amp fuse in a 20 amp circuit. It'll take twice as many amps to trip that fuse and that can be a bad thing... I'm not saying that you should NOT put a fuse/fuse link - I'm saying if you're using both circuits, you should divide the fusable link by 2 and use 2 of them in parallel. I always upgrade my electrical system on early toyotas. The factory wiring gauge is simply too weak for 15-25 year old vehicles. I use 4ga wiring to the starter and to both ground points. I see no reason to use better wire than 4ga for our electrical systems. If you've got a big alternator, replacing that wire should be manditory.. On 1st gen pickups, I've seen the stock alternator wire get old, start to heat up, and generally go bad on that weak-ass 40A alternator. If the wiring is in good shape (it tends to go bad at either end) and you've got a stock alternator, I wouldn't mess with it... Just my .01.
__________________
http://www.22REturbo.net |
#25 (permalink) |
I went with 1/0 everywhere since I compete and every 0.1dB counts, and well, big wire is cool as hell too!
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Who has done the "BIG 3" wire upgrade? | 03TRDBlack | 95.5-2004 Tacomas & 96-2002 4Runners | 15 | 12-12-2008 05:03 PM |
| Tundra 231mm "big brake" upgrade kit w/Slotted rotors | DeathCougar | The Classifieds GraveYard | 9 | 05-24-2007 03:42 PM |
| 1/0 AWG overkill for big three upgrade? | 4-RUNNIN' FREAK | Vehicle Audio & Home Entertainment | 10 | 04-21-2006 07:21 PM |
| Ground Wire Upgrade | MarkieMark | 95.5-2004 Tacomas & 96-2002 4Runners | 18 | 08-18-2005 11:49 AM |
| Group Buy, Big Motor Upgrade, First 55 Only | BT17R | Off Topic Talk | 11 | 11-11-2004 09:21 AM |
