"big 3" brain drain
"big 3" brain drain
Hi All,
1992 4Runner 5 speed/22RE here.. in process of rebuilding the engine and wanted to take care of some other things while I have room, etc. I have now read entirely too many posts about alternator to battery wiring specifically, and am unsure how to proceed. I know what I would LIKE to do, but am not sure if it will work or what the ramifications are, so I want to run it by the community before proceeding.
The ground components of the "big 3" I have no issue with. There's really more than 3, so here are the grounds I'm focused on replacing/upgrading with:
The positive side is where I'm getting spun out a bit.. my GOAL is to Replace wiring from alt to battery with new clean fresh wire, and plan ahead for an upgraded alternator down the road.
How do I best/easiest do this?
Keep in mind, for now I'm using the stock alternator with no additional power drains, other than maybe some minimal additional off-road lights and the upgraded headlight harness.
My thought is to basically follow what I'm reading about in this thread (post 5): https://www.yotatech.com/forums/f116.../#post52292646
To sum up: Install NEW 1/0 alternator + direct to battery +, with an in-line fuse (80 amp for now but future upgrade-able). DITCH the current alternator charge line that terminates in the fuse block, but leave all other connections in place. Also replace the battery + to fuse block 80 amp fuse, again leaving all other wiring in place. Also include a fusible link in the replacement wiring.
Am I understanding this correctly, and will what I'm wanting to do work correctly, without any charging issues, gauge malfunctioning, or anything else weird? I just want it all to work the same as it does now.
Thanks..
- Battery - to block (1/0)
- Batttery - to chassis (6 gauge here)
- Head to firewall (6 gauge here)
- Alternator to body (1/0 here if I can)
Thanks..
There's actually an existing driver's side ground running from the driver side fender to the alternator bracket. The previous owner had hacked it up so it was sort of just wire tied in there - I assumed it needs to be there?
FS[PacNorWest]: CLEAN 1985 4runner oba,s/c 3.4, arbs, 37's, duels
yota864x4
11-16-2016 01:02 PM
mechagouki
12-20-2015 04:06 PM
Whitemoneypit
20
11-01-2015 10:20 AM
