| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
#2 (permalink) |
you should be able to check if your alternator is working with the voltage meter.
#3 (permalink) |
Instructions on how to do so?
__________________
87 4runner 22re 200,000+ miles and still going! |
#4 (permalink) |
I did it a few years ago with my dad, we just started the car then held it on the positive and negative(or ground maybe) terminals on the alternator.
Does anyone else on here know if i am correct? |
#5 (permalink) |
well it does sound like you would be right on this one
__________________
85 4runner 4x4,3.slow v6 EFI auto,45k miles on rebuilt engine & tranny,SAS,dual magnaflow exhaust straight pipe,sunroof,billet grille,lifted,37" nitto mud tires,92 front bumper,shaved door handles & side marker lights,custom two tone paint job DD 2001 Tacoma Prerunner TRD ext cab,bf Goodrich all terrains,blacked out rims |
#6 (permalink) |
Ok, heres an update: I have not tested the alternator myself but I HAVE noticed one thing. The parking brake light stays on but it shouldn't, the brake is not engaged in any way. I had the voltage meter hooked up to the battery at one point and noticed the brake light go off, when this happened the alternator kicked in and the battery charge went up to 13.6 or so. When the light is on it will not charge, when it's not on it charges properly. Does this mean a short somewhere? A bad relay? None of the relays in the small box looked bad though..
__________________
87 4runner 22re 200,000+ miles and still going! Last edited by dewijw01; 08-21-2009 at 09:42 AM. |
#7 (permalink) |
The brake light will come on with the charge light when the alternator isn't charging with the engine running. There are several threads on this topic here somewhere. I have been having the same problem with intermittent charging from the alt. and the two lights coming on. I replaced the alternator with a Toyota remanufactured one ordered from Toyota of Dallas. I also replaced the original-looking negative battery cable due to corrosion and fraying of the cable. (I've had the truck for a year now and finally got to it.)
All seems to be working normally now. I'd suggest you replace the alternator, or borrow one from someone to test and see if your alternator is the problem.
__________________
'89 V6, 5 spd truck and '07 FJ Cruiser |
#8 (permalink) |
CHECK THE BRUSH'S
$9.00 fix if you replace them it will save you from buying a new alternator , check 4crawler.com he has a nice wright up about it and I believe you can get the brush's from his site.
__________________
1990 4 runner 5 Speed Pro Comp Stage II 4" Lift 6" coils rear Aussie Locker front 5.29's Front And Rear 35 x 12.5 x 15 MT's Micky Thompson Classic II Wheels Super Charged 3.4 on the way 1993 SAS 4runner 22re 5 speed 4" front 5"rear 5.29's 35 x 12.5 BFG KM'S Dick cepek DC 1's 88 stock 4runner 3.0 auto for now 1955 Harley Davidson Springer Stock 1955 Hardtail Frame 4 Speed Kick Start Only 1998 Harley Custom Dresser 107 rwhp 139 ft.lbs.trq. |
#9 (permalink) |
Ok, havent had time to dig into it again but I will get new brushes and try that.
__________________
#10 (permalink) |
i was in the same boat...alt. tested good...checked everything else..nothings wrong...replaced the alt. with a new one from Oreiley's..and everything is fine so far...
except for my ignition module and coil going out.. ![]()
__________________
FOR SALE 1986 Ext. Cab 4x4, rebuilt 22R, 5spd, 31x10.50 X-Terrains FOR SALE 1992 SR5 FO RUNNA V6, 5 speed, 4in. trail-master lift, 33x12.50 BFG muds, 4.56 gears!!! and an IMMACULATE interior..yes..you should be jealous "Its still a toyota man.. Dont deprive it of its capabilities.." "If you can read english, Thank a teacher...If you can speak it, Thank a soldier!!" Kelli Ruark-2009 |
#11 (permalink) | |
Quote:
I wish I'd read more about this before ordering and installing an alternator. But at least now I have a good Toyota remanufactured unit to work with if it ever gives me trouble again.
__________________
#12 (permalink) |
Now you say you changed the battery terminals . Did you crimp new ones on??
I have found that these vehicles come with very poor ground systems and over time they degrade even more . A alternator or starter that works on the bench but is a few years old might not work in the vehicle . Where a new or rebuilt unit being fresh will work for a period of time could be weeks months or years When I get a new Toyota to me first fix is always to upgrade the battery terminals and cables . I use the cut off ends of number one welding cable cables damaged by something dropped or burnt like 5' or 6' from the end and Deka marine battery terminals . This has fixed a number of charging and starting issues |
#13 (permalink) |
Well, changed the brushes in the alternator (3.99 from Napa) and all is well so far.... *fingers crossed*. If it dies again I will be back on here hah.
And as for the terminals being changed, the negative one came with a little metal bracket that tightens the two neg wires together. It seems to be holding fine.
__________________
| Tags |
| 4runner, alt, alternator, bad, batt, batteries, battery, car, charging, good, harley, properly, toyota, truck, workin |
