| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Auxilary Relay Block?
#2 (permalink) |
I was looking everywhere for the same sort of thing.
I found this $40 Hella block, which can be dovetailed to one of their $35 fuse boxes. Nice, but very pricey: Hella Relay Block I bought a bunch of relay holders from Painless wiring. They can be dovetailed together and I planned to mount one inside and 2 outside of the stock under hood fuse box. Then, I decided to try and find another fuse box with relay mounts. That way I could do away with my Blue Sea fusebox and have fuses and relays in one convenient location. EG and EK Civic boxes looked to be a decent size and are cheap, but I gave up on this since I couldn't find good wiring diagrams to get it to work. Finally, I stumbled across a relay box from a 90-93 Celica on ebay. It has places to mount 5 high quality Toyota Denso relays, it's small and most of them are cut with enough wire to easily add them with minimal fuss. I found one with all relays on a Celica forum for $20 shipped. The 4 relays alone are worth $80! These relays can be wired the same as any 4 pin Bosch relay for lights, fans, etc. And they'll last far longer than the junk ones you get at Checker. A great option if you can find one cheap. Fits in the void next to the brake booster and evap box with appropriate bracketing. ![]()
| Tags |
| 93, block, bosch, box, civic, fuse, hella, holders, location, mounting, mounts, pin, pw, relay |
