| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Aux. lighting wiring......
__________________
2000 Toyota 4runner auto, 4x4, elocker, budbuilt skid, Sonoran Steel 7.2, 265/75/16 Yokohoma Geolanders AT-S Just call me "T" |
#2 (permalink) |
im using 8ga wire for mine and its attached to the cowl vent part on the firewall with small self tapping screws
#3 (permalink) |
Well, I ended up ordering the following from Marine Technology.
Blue Sea 5025 ATO Fuse Block, 6-Circuit with Cover and Negative Bus Blue Sea 5001 SEA Mega Fuse Block Blue Sea Mega SEA Fuses 100A-300A (ordered a 100amp fuse, fiqured that be enough). OEM Toyota Foglight Switch
__________________
2000 Toyota 4runner auto, 4x4, elocker, budbuilt skid, Sonoran Steel 7.2, 265/75/16 Yokohoma Geolanders AT-S Just call me "T" Last edited by wormhole; 09-29-2009 at 10:01 PM. |
#4 (permalink) |
if i was you i would run relays if your not already... provides for a cheaper install as you dont have to run heavier wire to your switch and back. dont know how much experience you have in electrical so dont take this the wrong way if you know what your doing, if your using a 100 amp fuse for the power to the distrubution block make sure the wire you are using is rated for 100 amp's... i can tell you that 8 gauge is NOT rated for 100 amps. i would run 2 gauge wire from the positive terminal to the block and depending on what your draw is, run the required gauge wire to your relay from the block and from the relay to the load. let me know if you want more help.
-Mitch |
#5 (permalink) |
Got to love the brown santa.
![]() 1989SHO19992SR5 - The wiring is the only thing I still have to fiqure out.
__________________
#6 (permalink) |
but you understood what i was saying correct?
#7 (permalink) |
Some thoughts for you:
1. Your main fuse (100A) should be as close to the battery as possible. This is sized quite large for an auxiliary fuse block. You should add up your expected load and consider what devices will be used concurrently, then size the main fuse slightly larger. 100A may be fine, smaller is better if you can get away with it. Carry a few spares and maybe keep the 100A in the glove box for emergency use if you go with a smaller main. 2. Downstream fuses (in your fuse block) should be rated for a current slightly higher than the end device consumes. For instance, if your lights are rated 100 watts @ 12 volts then 100/12 = 8.33 Amps. Choose a fuse size of 10, 12 (do they make a 12?) or 15 amps. 3. Wire should be sized at least to expected load and then slightly larger would be good. I don't recall small wire current ratings (I'm a power engineer, not electronics!) but again if your lights are 100 watts, choose a wire that will cary at least 20 amps or so. This is of course more current than your lights will draw, but if you choose a wire which is rated at 20 amps and fused at 15 amps then you won't cook your wire if something shorts. Generally the current rating of a wire will be somewhere on the package. 4. Screw the fuse blocks down to the firewall, 700 amps @ 12 volts (typical truck battery) can do devastating damage under the hood if your velcro failed! |
#8 (permalink) |
Ok. If I got this fiqured correctly.
Lightforce 170 lights - 12v x 100w = 8.33 amps per light Piaa 510's - 12v x 55w = 4.5833 amps per light Cobra ST WXST II CB - 12v x 4w (I believe) = .33 amps Total amp - approx. 30 amps. So 7 gauge wire would then (I won't use it though)? Could I get away with 6 gauage? http://www.powerstream.com/Wire_Size.htm
__________________
2000 Toyota 4runner auto, 4x4, elocker, budbuilt skid, Sonoran Steel 7.2, 265/75/16 Yokohoma Geolanders AT-S Just call me "T" Last edited by wormhole; 10-12-2009 at 05:59 PM. |
#9 (permalink) |
You'd be ok with 6 but I would suggest using 8 and a 60 amp fuse. Those sizes would be for your main of course.
Something else worth mentioning. I would try and stick with the same size conductor that is supplied with your devices, likely 12 or 14 for your lights and 16, 18 or 20 for your radio. You'll notice that the table lists the MAXIMUM current capacity, no reason to push this limit. Your lights especially, use 12, it will be more durable and you'll never approach burning up your wire before you blow a fuse. |
#10 (permalink) |
Okay, stupid question. I understand how to run the aux lights to the fuse panel but then from there how do I run them to the switch?
__________________
#11 (permalink) |
Hmm... depends on the type of switch you have, does it have two terminals on the back or three?
Were you supplied a relay with your kit? If not you might think about getting one. Let me know, we'll go from there. Also, many of the light manufacturers have wiring directions on their sites with diagrams, might want to check that out. |
#12 (permalink) | |
Quote:
I'm using Toyota fog light switches. The PIAA lights I'm untilizing all three pongs on the back of the switch. However on the Lightforce lights the switch they provided only has two pongs where the Toyota switch has the three (as I mentioned). Now does this make sense on my thinking with the wiring: Would I just need to splice together the positive, negative and ground wire together for each respective wire (ie. positive from lights and postive from a switch to one of the positive post on the fuse block, like wise for negative and ground) or is there something else I'm not thinking of. Hopefully, this make sese I've never been very good with wiring up switches like this.
__________________
#13 (permalink) |
so your using the supplied wiring kits? then using your toyota switc instead of the other one... okay the three prong switches have a load 12v, line 12v and gound. (dont need the ground unless you want to have it light up) line is your voltage in and load is voltage out. hope thie makes sence. also please do not over size the fuse as limon43 mentioned... 8 gauge is not rated for 60 amp, its rated for 40... use a 40 amp fuse.
#14 (permalink) | |
Quote:
To be clear, I suggested UNDER sizing the fuse, not over, which I completely agree with. As for current carrying capacity of your wire, it can vary with the type of wire used (number of strands being the primary difference), 60 amps for 8 gauge happened to be the spec for the table i was reading. To the original poster, i'd suggest you find a data sheet for your particular wire and determine the actual rated ampacity, or fuse it for 20 percent less than the average of a few tables worth of values from google, if you can't find the data sheet. Lastly, both of your switches work in a basic manner, interupt the 12v lead which operates your relays. The switch with two terminals can be wired between your +12V source (likely an ignition controlled fuse in your main fuse box) and your relay. The three terminal switch works the same way, save for a third terminal which is usually a ground if it is a lighted switch (most likely your case?). You need to figure out which terminal is the ground and make sure its grounded if you want the light to work. If your using the light, then the load side of the switch becomes important. It must be the terminal to which your relay is connected. The source side of the switch would go to your 12V source. If you don't want the light in the switch, the ground doesn't need to be hooked up and the source and load terminals no longer serve a distinctly different purpose, unless there is an off/on label on the button. |
#15 (permalink) |
The wiring kit I got with the lights has the connections to connect to the positive and nagative battery post. Since I'm going to be running the lights off an auxiliary fuse block would I just then connect those wires to the fuse box since the block will already be wired to the battery?
__________________
#16 (permalink) |
Depends on which wires your talking about.
The positive lead should be connected to your fuse block. Your grounds should be grounded at the closest point possible. For example, each light should be grounded individually to the frame or some other good ground point. I usually use the mounting bolt of the light. The ground to your switch should be grounded somewhere near the switch, the ground for your relay can go under the relay mounting screw, and so on. Does that make sense? |
#17 (permalink) | |
What's the best way to wire an aux. fuse block to only turn on while the ignition is on? Is this the best way to wire an aux. fuse block? Or should it be wired to be on all the time, regardless if the ignition is on or off? I plan on running 2 forward facing lights and probably 3 pair of rock lights (all on relays of course).
__________________
1984 Toyota 4Runner EFI swap TG 4" springs Marlin Crawler Dual Ultimate Crawler 39.5" Iroks Addicted Off Road 8 point cage Addicted Off Road front bumper Addicted Off Road My 4 wheel drive club http://www.rockfrogs.org Quote:
#18 (permalink) |
mine is hook straight to the battery with fuse that means its hot all the time
__________________
My Truck 98 4runner SR5 3.4L 5spd 4x4 E-Locker Mods Mom 07 Tundra d-cab limited 5.7L 4x4 auto sister 92 pickup SR5 X-cab 3.0L 5spd 4x4 Papa 89 Pickup SR5 X-cab 4x4 3.0L 5spd/98 4runner SR5 4x4 auto 3.4L R.I.P 91 4runner SR5 4x4 3.0L 5spd Totaled 5/13/06 My Wreck Last edited by Elton; 11-02-2009 at 10:57 PM. |
#19 (permalink) |
I finally found a relay box that was cheap and works great. It's the radiator fan relay box out of a 90-93 Celica.
#20 (permalink) | |
Quote:
One note of caution, typical automotive relays are 30A or 40A, if you need more than that you might be able to find a higher rated 12V DC relay online or you can run multiple "main" wires and multiple relays in parallel, like 2 40's if you need 80A. |
#21 (permalink) |
Wormhole, I just read this entire thread and I want to make sure that you understand the sizing basis for the fuse that goes between the auxillary block and the battery (even though many have already said this). The fuse needs to be smaller than the rating for the wire that you use. The only purpose for that fuse is to keep the wire from burning in case of a short. You asked about 6 gauge wire. 6 gauge is not rated for 100 Amps. Again, the fuse needs to be sized for the connecting wire, not for the ultimate load on the fuse block. The fuses in the fuse block protect all the wiring downstream of the fuse block.
FWIW, I installed that same fuse block on my firewall. I used less than 3' of 6 gauge wire with an 80 amp fuse. I haven't look at a chart but you would need 2 or maybe 4 gauge wire for a short run protected by a 100 amp fuse. Good luck with the wiring.
__________________
1985 4Runner 1997 FZJ 80 2007 HDJ100 - DD |
