Another alternator question 89 22r
Same problem as in the previous thread, brake and battery light on. I pulled the alternator and wanted to attempt changing the brushes. I've never done it before and the worse thing that happens is I screw up and got to get a new alternator. I bought the whole Nippon denso brush holder assembly on ebay for like 8 bucks. I got out the old brushes and the lower one was sticking, gummed up and looked worn beyond limits, so probably that was it. However, when I removed the old assembly, it cracked up. No big deal. Also the rubber cap that goes over the brush holder tore on one side when I pulled it up to get the old brush unit out. After installing the new unit I got this rubber thing back on somewhat snugly, but it is a little warped and now one side is torn. Does any one know if this will effect the operation of the alternator?
Thanks for the info. Also, I have never opened up an alternator; it is a little greasy in there. Is this normal? The thing was actually working most of the time before I pulled it anyways. The batt and brake light was an intermittent problem on startup and usually went away. I thought I would just nip this problem in the bud.
problem well-stated is a problem half-solved. What rubber thing? pics?
Not normal but expected of an old truck; pulleys/belt would fling oil at the alternator. Someday, when there's enough dirt deposits there, that junk could get conductive and cause shorts or mess up brush operation.
Intermittent meaning it could strike at the wrong place, wrong time. Fix it.
See charging system link on my sig. Has simple test points you could use.
It is a little greasy in there. Is this normal?
Thanks for the good reply. I am putting this alternator back in today or tomorrow. I will post back up how its working. Hopefully it works. If it does, this seems to be the way to go. Before junking an alternator. It is a really good idea to check these brushes. It seems pretty easy, but I can't really say that yet, I don't know if it works
Well got the alternator in this morning. Started right up and I've got 14.7 volts at the battery! So far so good. It was an intermittent problem, so I can't call it good for a few days, but I think that was it. I've got to say before buying a new alternator, try the brushes. It is easy, just be careful of the rubber cap over the brush holder, I tore mine, but it still seems to work anyway!
