Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
Alternator Help
Alright A while back while driving home the back nut on the bottom bolt of my alternator rattled itself off, when this happend the + conneection on the alternator broke off.
So i figured I'd just re-connect the connection right? Wrong. When i re-connected it i thought that would be it, but it still woudlnt hold charge. So i thought the alternator might be the problem, so i replaced it - Still wouldnt hold a charge with the new one. This is where i started to get rattled, so maybe the wire broke itself somewhere? It still had continuity though but the wire itself is only 12-guage. I talked to a friend of mine and he said that maybe i wasn't getting enough juice through the skinny wire. Made sense, so i ran a double stranded 4-guage wire straight from my alternator to my battery. This worked amazing for about 4 days, but not its not holding charge again! Now before this all happened it worked perfect, held my battery at 16 volts while running tons of accesories. The new alternator i put on was only 40 amps, maybe the old one was more? Sorry to type so much but im stuck on this one. Any help would be appreciated I'm stuck on this one Thanks, -Newton
__________________
RIP: 1985 4runner, 2" lift in shackles, had big plans for it before i snapped it in two =( sold: 1982 yota 4x4 P/U, SWB, short bed, 4.37's, 6" skyjacker lift, 33"x12.5"R15 bf all-terrains on AM rims, K&N Intake and filters, 8.8mm wires and cap& rotor, magnaflow duals - headers back Current: 1990 toyota 4x4 p-up, ext. cab , 3.0 v6 5-speed, powder-coated frame, powder-coated rims, tint all around, rancho 9000's, good old cherry bomb, and soem 31" kumho meatballs Last edited by 82greenbeast : 06-30-2008 at 08:26 PM. |
| Sponsored Links |
#2 (permalink) |
anyone?
__________________
RIP: 1985 4runner, 2" lift in shackles, had big plans for it before i snapped it in two =( sold: 1982 yota 4x4 P/U, SWB, short bed, 4.37's, 6" skyjacker lift, 33"x12.5"R15 bf all-terrains on AM rims, K&N Intake and filters, 8.8mm wires and cap& rotor, magnaflow duals - headers back Current: 1990 toyota 4x4 p-up, ext. cab , 3.0 v6 5-speed, powder-coated frame, powder-coated rims, tint all around, rancho 9000's, good old cherry bomb, and soem 31" kumho meatballs |
#3 (permalink) |
Nice 1st gen. Are you sure your battery is ok?
Rob
__________________
1988 Xtra Cab Pickup ('94 22RE; 4x4; 5spd) Rancho lift w/ 33x12.5x15 tires & 5.29s |
#4 (permalink) |
It wasn't, but i replaced with a new one, and still had the same problem
__________________
#5 (permalink) |
something wrong with the regulator if it was charging at 16 volts.
__________________
1984 toyota sr5 4x4 22r w/ weber 32/36 Pro comp 4" front springs and 3" rear downey springs D-tech Shocks 33x12.5 M/T , 15 inch weld rims Hella 550/ Hella h4 conversions with HID Home made On-board air system Last edited by deserttoy84 : 07-13-2008 at 10:36 PM. |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| How can I tell which alternator I have? | runnerSR5 | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 10-13-2006 01:34 PM |
| wrong alternator by Mr Alternator | funrunner91 | 86-95 Trucks & 4Runners | 21 | 07-03-2006 11:06 AM |
| Mr. Alternator?? | photomike72 | General Vehicle Related Topics (Non Year Related) | 27 | 12-31-2005 02:58 PM |
| New alternator? | SeanSaubers | Vehicle Audio & Home Entertainment | 7 | 11-08-2004 06:12 PM |
| alternator help!!?? | fourunnabilly | 95.5-2004 Tacomas & 96-2002 4Runners | 0 | 08-24-2003 08:10 PM |
