Alarm wiring issues 2nd gen pickup Help - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > General Electrical & Lighting Related Topics
Welcome to Yotatech!
Welcome to Yotatech,
Old 02-03-2007, 05:57 PM   #1 (permalink)
Drama Queen/Banned
I went to install my Viper alarm today; everything went smooth, except wiring the starter disable.
I used a test light to test a starter circuit under the steering column. I found a nice thick wire on the ignition switch harness that would only light up when in the key was in crank position (wire is red and brown). So I clipped the wire and just for peace of mind decided to see if the starter would crank and it not only cranks, but the truck starts.
I'm now completely baffled as I cannot find any other wires on this circuit that send juice to the starter while only in the crank mode. This is my first alarm install.
Any ideas of which wire should be used to disable the starter at the ignition switch? A scematic of all the wires off the switch would help
Truck is an 1985 carb 4x4 pickup
paxil4x4 is offline
Old 02-04-2007, 02:40 PM   #2 (permalink)
BlackSR5's Avatar
starter should be black/white or black...
BlackSR5 is offline
Old 02-08-2007, 02:29 AM   #3 (permalink)
just a 22re's Avatar
Send a message via AIM to just a 22re Send a message via Yahoo to just a 22re
ok ok i did this for 3 years so just give me a call and ill walk you throgh it my number is 414 6+533540 i have a print up on the color codes for 87 year but im sure there a the same later
just a 22re is offline
Old 02-08-2007, 06:18 AM   #4 (permalink)
Sponsoring Member
midiwall's Avatar
psssssssst...
http://www.commandocaralarms.com/wir.../Toyota/Pickup
__________________
~ Mark
'96 4Runner Limited S/C MI - 370cc injectors, Air! horns, Airaid MIT, ATS A-arms, 285/75/R16 BFG MTs, Bored TB, Brembo slotted, Cobra 75 WXST, Deckplate, Downey headers, Hayden cooler, IPT valve body, Level 10 torque convertor, Meanstreak exhaust, OME/OME rears, On-board PC (XM, Nav, WiFi, etc), Port 'n Polish, Remote Start, SAW fronts, Hilux console, SMT-5, Stubb's sliders, Supra MAF, TJM-17, 2.0" pulley, Viair 450c, Walbro 190, Weasy2k cams
midiwall is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
2nd Gen. Alarm help please... 4x4Lamm Vehicle Audio & Home Entertainment 0 09-27-2005 07:49 PM
2nd gen owners w/ factory alarm. Questions SLC Punk 95.5-2004 Tacomas & 96-2002 4Runners 0 01-13-2005 12:39 PM
can a 3rd gen axle with locker and all wiring be added to a 2nd gen scubasteve83 95.5-2004 Tacomas & 96-2002 4Runners 20 01-09-2004 09:33 PM
Help! 2nd gen factory alarm problems CMD93 95.5-2004 Tacomas & 96-2002 4Runners 5 12-01-2003 05:59 AM
2nd Gen Alarm Options mchan77 95.5-2004 Tacomas & 96-2002 4Runners 1 09-30-2003 07:02 PM
2009 InternetBrands, Inc.
