YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > General Electrical & Lighting Related Topics
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 07-19-2008, 09:01 AM   #1 (permalink)
toyNG's Avatar
AC/heater blower stopped working
Got in my truck the other day and the blower suddenly doesn't work. I've done a search to help diagnose the problem. My question is, does anyone know of a link to a simple guide to fixing this? Preferably one with pictures, as I'm a newbie to mechanics in general, but especially a newbie to electrical. thanks!
__________________
1986 pickup 4x4 SR5, 31x10.5 BFG All-Terrains, Ranchos, 2" body lift, Downey grille guard and skid plate, TG sliders
toyNG is offline
Sponsored Links
To remove this ad, register today!
Old 07-19-2008, 09:50 AM   #2 (permalink)
4Crawler's Avatar
http://www.4crawler.com/4x4/CheapTricks/Blower.shtml
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs.
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 07-19-2008, 11:52 AM   #3 (permalink)
toyNG's Avatar
problem is that I'm such a newbie that I need help testing the relay and switch. thanks for the link though.
__________________
toyNG is offline
Old 07-19-2008, 12:05 PM   #4 (permalink)
4Crawler's Avatar
To test the switch, use a test light or ohm meter to see if it is making contact. Usually it is fails, it is due to excess heat and the plastic melts, so quite obvious if it has failed.
Relay testing can be done in two steps, #1 put your finger on it and turn the blower switch on and off. If you can feel the relay click on and off, the coil part is likely working. Then test like a switch, see if power is coming out of the relay. Also test the fuse.
__________________
r.c.brown@ieee.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 07-19-2008, 12:57 PM   #5 (permalink)
toyNG's Avatar
thanks 4crawler! is there an easy way to get to the switch without removing the whole 9 yards? i'm doubting that there is, but I thought I'd ask anyways.
__________________
toyNG is offline
Old 07-19-2008, 02:02 PM   #6 (permalink)
4Crawler's Avatar
No idea, never had problems with mine, so never looked into removing it. My theory of troubleshooting is to start with the easiest to get to things and work back towards the harder to get to things. So fuse, motor, resistor, relay, then lastly switch.
__________________
r.c.brown@ieee.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 07-19-2008, 02:45 PM   #7 (permalink)
toyNG's Avatar
thanks man, you're awesome. I just got the blower off. I'm guessing that Toyota must have used Japanese contortionists to put that rear screw on...that thing was a PITA to get to!. But anyways, it looks like I'll be ordering a brush replacement set from you. How do I go about doing that?
__________________
toyNG is offline
Old 07-19-2008, 03:08 PM   #8 (permalink)
4Crawler's Avatar
Replacement blower motor brush information:
- http://www.4crawler.com/4x4/CheapTri...OnlineOrdering
__________________
r.c.brown@ieee.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
heater/blower controls Al's Chop Shop Pre 84 Trucks 20 06-04-2008 02:41 PM
fan/blower/switch stopped functioning idanity 86-95 Trucks & 4Runners 6 12-03-2007 03:33 PM
ac and heater blower fan? GMJK86SR5 86-95 Trucks & 4Runners 2 05-15-2007 01:38 PM
Blower stopped working on '07 Tacoma Mark in MD General Electrical & Lighting Related Topics 6 05-07-2007 06:52 PM
Heater and Blower Questions SwampThing 86-95 Trucks & 4Runners 9 09-26-2006 09:11 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
