YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > General Electrical & Lighting Related Topics
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 07-06-2008, 06:38 PM   #1 (permalink)
Runner003's Avatar
Send a message via MSN to Runner003 Send a message via Yahoo to Runner003
99 4runner power antenna broke
Hi all,
(Yes, I did the search) however, couldn't find what i was looking for.
I have a 99 4runner (pride & joy) with a broken Power antenna that is stuck up (much like my last girlfriend) Anyways,
I want to pull the fuse to keep the antenna from making noise everytime I turn on the stereo. Is there a dedicated fuse for this? and, if you have experience getting this fixed via dealership what am I looking at in costs for this.
Thanks much,
Darren
Northridge, CA
Runner003 is offline
Sponsored Links
To remove this ad, register today!
Old 07-06-2008, 07:35 PM   #2 (permalink)
4Crawler's Avatar
Not sure on the 3rd gen, but on my 1st gen, no separate fuse. Probably easiest to disconnect the power plug at the antenna motor. ANd typically not that hard to repair yourself:
- http://www.4crawler.com/4x4/CheapTri...ent/index.html
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs.
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 07-06-2008, 07:52 PM   #3 (permalink)
misterzee's Avatar
Send a message via Yahoo to misterzee
you can get a replacement mast for half of the dealerships price on the "bay"... i have bought several that way successfully...
Usually, unfortunately, a piece of the plastic end is broken in the motor unit, and you have to remove it, disassemle, clean it out, relube, reinstall, then install the new mast. its remotely possible that you can get it all out from the top... then all you do is turn your radio ON, so the mast is pushed up, and slip the end piece down in there and position everything just so, turn the radio off, and it sucks everythign back down inside, and you're 'installed', just tighten the little ring and you're done. BUT you have to be sure any fragments of plastic are out of the lower unit....
__________________
85, 87, 96 4Runners, all males...
03 Town and Country... female
CLIK4PIX
misterzee is offline
Old 07-06-2008, 08:08 PM   #4 (permalink)
You can unplug it from the motor if you move the plastic from the wheelwell under the antenna motor.
Yukon is offline
Old 07-06-2008, 09:04 PM   #5 (permalink)
Runner003's Avatar
Thanks soo much guys, I'm just going to get the under "carage" of the fender off and pull the plug.
I was just hoping to be lazy - like just humming to work so I don't hear the gnaw of the antenna motor going for 30 seconds. LOL
You guys rock.
D-
Old 07-06-2008, 09:06 PM   #6 (permalink)
Elton's Avatar
Send a message via AIM to Elton Send a message via MSN to Elton
remove the stereo now look for a little plastic box wont be hard to spot it says antenna relay unplug that and your done
__________________
My Truck 98 4runner SR5 3.4L 5spd 4x4 E-Locker Mods
Mom 07 Tundra d-cab limited 5.7L 4x4 auto
mom 92 pickup SR5 X-cab 3.0L 5spd 4x4
Papa 89 Pickup SR5 X-cab 4x4 3.0L 5spd/98 4runner SR5 4x4 auto 3.4L
R.I.P 91 4runner SR5 4x4 3.0L 5spd Totaled 5/13/06 My Wreck
Elton is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
4runner power antenna dutchboy General Electrical & Lighting Related Topics 2 07-04-2008 11:42 PM
WTB:89 4runner drivers side power window switch and power antenna 4cylpwr Items Wanted 1 07-02-2008 06:34 AM
T100 Power Antenna Broke CJM 93-98 T100s 8 09-08-2006 05:14 PM
4Runner Power antenna questions kenfused 95.5-2004 Tacomas & 96-2002 4Runners 14 01-05-2005 10:22 AM
Power antenna broke: What other options do I have? <96 Runner> 95.5-2004 Tacomas & 96-2002 4Runners 27 11-02-2004 05:07 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
