98 tacoma power window - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > General Electrical & Lighting Related Topics
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-31-2009, 05:24 PM   #1 (permalink)
Just finished fixing my driver's side power window on my 98 Tacoma. A couple of days ago it quit working. Last night I found that the wires that power the lift motor had pulled out of their connector shell due to NO SLACK AT ALL. Seemed kind of weird, so I assumed that someone had been in there in the past and mis-mounted some clip-in-a-hole connector somewhere.
Today I discovered that a couple of the bolts holding the regulator/motor/lift ass'y. to the door had worked their way out. Thus when power was applied to the motor it spent part of its work pulling away from the connector instead of raising and lowering the window. Replaced bolts and AHA! problem solved.
Now I need to replace the plastic rain shield sheeting but I'm lazy so put it all back together minus the sheeting for now. Besides, Wyoming is a pretty dry climate. Shouldn't rain again here until next Spring. Plenty of time to forget to do that chore. <8-0
banjodan in Wyo.
banjodan is offline
Tags
problems, quit, tacoma, window, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
