Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
98 4Runner Window switch slowly going out?
I have a 98 4-Runner and the windows are slowly not responding to the switch, either the master, nor the local door switch. The driver's side front works fine, and the passenger's rear works fine as well. The problem is that the driver's rear stopped responding to the switch, and about a month later, the passenger's front stopped responding and now the window is stuck down, but if you press "down" on the switch, it goes down just fine. I should add that the "up" function worked well and was not sluggish before it stopped responding.
What could be the problem, and how can I get the window up at least manually for now? Thanks for any responses. Poindexter |
| Sponsored Links |
#2 (permalink) | |
okay,i am no expert, but when you press the switch on the windows that dont work, can you hear the motor in the door?
__________________
1990 4runner SR5, 3.0 with 254K, 5-speed, 4.56 gears, , Rancho 9000's, 33X12.50's trxus mt's, rear lock right, 4" lift with lc coils in rear Quote:
My build thread http://www.yotatech.com/f152/904_run...thread-158746/ |
#3 (permalink) |
I had a similar issue in a Ford Ranger. I pulled the switches apart and cleaned the contacts and it worked fine after that. You also may have a loose wiring harness or bad contacts there, since it's multiple windows that are affected.
If you hear the motor running in the door (like 904_runner said), it could be a bad motor or regulator. Let us know what you find out!
__________________
1997 4Runner Ltd, E-locker, OME 881/906's with black Tokico's, 265/75/16 Yokohama Geolander AT+II's, 1000w inverter, dual batt setup My Profile 1998 Rocky Mountain Element TO (Canada Red) |
#4 (permalink) | |
Quote:
__________________
"And they called him a Hebrew Slave" 2003 Tacoma Prerunner, Double cab, 3.4 V6 5VZ-FE, auto. 2wd, rear e-locker My Profile (06/09/07)-Deckplate-(07/14/07)-ISR-(08/27/07)-WARN 4300K HID lights-(11/22/07) -True-Cool Tranny Cooler-(12/25/07) -Tru Flow air filter-(12/25/07) -Husky Floor Liners-(02/14/08)-ScanGaugeII-(04/30/08)-Glassworks Unlimited hood- |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| WTB: Rear Window Switch 88 4Runner | 4RunnerFreedom | Misc Stuff (Vehicle Related) | 6 | 08-07-2008 02:16 PM |
| 01 4Runner master window switch | NorCalVP | Misc Stuff (Vehicle Related) | 0 | 10-19-2007 09:41 AM |
| 85 4runner rear window switch question | mean green | General Vehicle Related Topics (Non Year Related) | 1 | 07-13-2007 03:13 AM |
| 4runner Rear Window Switch 95 90 91 92 94 93 | CDUFF7 | Misc Stuff (Vehicle Related) | 1 | 11-08-2006 03:15 PM |
| 4runner Rear Window Switch | CDUFF7 | Misc Stuff (Vehicle Related) | 0 | 02-19-2006 08:52 PM |
