Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
85 4runner rear window problem
I know I know another dreaded rear window problem. Sorry guys.
I was wondering if there is a way to test the rear window on a 85 4runner. I noticed there was a tread explaining how to hook up a second gen window motor to a 12v battery. Can this be done with a 1st gen? Pictures would be helpful. Thanks! ![]()
__________________
1st gen 4runner interior for sale here 87 Turbo 4runner STOCK 85 4runner Build Thread 87 4runner (parts) 95 4runner 2wd auto |
| Sponsored Links |
#2 (permalink) |
#3 (permalink) |
Yeah ive already read all of that.
Does anyone know how I can just test the motor? I just need to get it down as I have a new tailgate waiting to be installed
__________________
#4 (permalink) |
Since the window is already up and you need it to go down it's going to be a little difficult. You'll need to crawl into the back of the truck, remove the carpet cover on the tailgate (screws) and then remove the metal protector plate under that (screws). This will expose the motor for the back window.
From here you need to locate the black plastic connector which has 2 wires running from it to the rear window motor. It is a click together type of plastic connection. Anyways, unconnect that black connection so you can see the two prongs/connectors inside of the black connector. It should look similar to the image below (minus the wiring to the switch since you will be bypassing it). ![]() Now from there you need to take two long wires and connect them from the window motor connection to the + or - of your battery. If you connect them and they do nothing, reverse them so the + is now on the - and the - is now on the +. This won't harm it as it just controls which direction the window moves. Hope this helps, let me know if you have any more questions and I'll give you a hand.
__________________
1987 4Runner - 22RE 5speed |
#5 (permalink) | |
Quote:
- http://www.4crawler.com/4x4/CheapTri...html#MotorTest connect 12 volts to one of the motor terminals and the other to ground. To test the other direction, swap power and ground connections.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs. r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club Last edited by 4Crawler : 08-11-2008 at 06:50 PM. |
#6 (permalink) |
Thanks everyone I finally got it down
__________________
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Rear Window Problem Help!!!!! | keithguts | 86-95 Trucks & 4Runners | 2 | 06-13-2008 10:27 AM |
| Rear window problem 88 4runner | 006roadster | 86-95 Trucks & 4Runners | 2 | 06-24-2007 05:44 PM |
| rear window problem | kcdee00 | 86-95 Trucks & 4Runners | 0 | 11-28-2006 04:34 AM |
| Rear window problem | swerks | 86-95 Trucks & 4Runners | 5 | 08-31-2006 07:46 PM |
| Rear window problem | Poopy | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 03-26-2005 09:47 PM |
