85 4runner fuel pump - YotaTech Forums
Go Back   >
General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
LinkBack Thread Tools Search this Thread
Old 03-28-2009, 02:03 PM   #1
toyota rebirth's Avatar
i can get the pump to work with the test plug but when you turn the key it dont come on. tried different ecu still nothing any suggestions.
toyota rebirth is offline   Reply With Quote
Old 03-28-2009, 02:32 PM   #2
have you tried the fuel pump relay?
DYNNOMMYTE is offline   Reply With Quote
Old 03-28-2009, 04:29 PM   #3
4Crawler's Avatar
Quote:
The fuel pump doesn't normally run with the key on, unless you have the test jumper installed:
- http://www.4crawler.com/4x4/CheapTri...shtml#FuelPump
Only way it runs is if the AFM vane is held open. Test that AFM and if that is OK, then check the circuit opening relay (there is no fuel pump relay, per se).
4Crawler is offline   Reply With Quote
Old 03-28-2009, 06:39 PM   #4
scuba's Avatar
I have a COR for sale if thats your problem
scuba is offline   Reply With Quote
Old 03-28-2009, 08:06 PM   #5
what is a cor. i checked relay it is efi. it dont even kick on to pressurize the system.
Old 03-28-2009, 10:24 PM   #6
scuba's Avatar
Read the link 4Crawler posted, He knows what's up.
Also,
http://www.personal.utulsa.edu/~nathan-buchanan/93fsm/
http://personal.utulsa.edu/~nathan-b...38circuito.pdf
Have you tried searching...?
Old 03-29-2009, 01:45 PM   #7
thanks for the help. got it figured out. feel kind of dumb didnt have tank in truck ran ground to it and started working.
87 22r rebuild issue bigjstang 86-95 Trucks & 4Runners 14 12-09-2016 10:16 PM
MMA_Alex's 1990 4Runner Build Thread MMA_Alex 86-95 Trucks & 4Runners (Build-Up Section) 22 06-14-2016 06:58 PM
4runner stalling in gear... Do this again please Jnkml 95.5-2004 Tacomas & 96-2002 4Runners 3 07-06-2015 02:20 PM
22rte troubles karbin Newbie Tech Section 1 07-06-2015 12:37 AM
New AC Questions (Not the same old ones) HRDC0R19 86-95 Trucks & 4Runners 3 07-05-2015 07:43 PM
Tags
22ret, 4runner, 86, 864, 87, 88, 89, efi, electric, fuel, prob, problems, pump, relay, runner
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
