81 will not shut off when ignition switched off
Ok got an electrical issue I hope you guys can help me out with.
Over the past few years my truck would intermittently not shut off when the ignition was shut off with the key. Now it never shuts down with ignition off. I have to step on the brakes and slowly let the clutch out. Obviously not ideal or safe.
I have traced wires (look fine), checked grounds, and replaced the switch in the column. No luck. Have not replaced solenoid or starter. Starter works fine, not sticking etc.
Any suggestions? 1981 Toyota with L52, 22r
