| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
4WD light not coming on: how to fix it
#2 (permalink) |
The 4WD light is a true indicator of wether 4WD is active. Chances are, you've got a vacuum leak somewhere.
__________________
~Eric 1991 4Runner 3.0L 4x4 Black, 31" Michelin M/S tires, OME-901's 1992 Lexus SC400 4.0 V8, Green with Tan interior (donor) (PM me for parts) Near Future: FI 1UZ swap. (June) Far Future mods: F/R Lockers, SAS, 35's. UZswap.com - A discussion forum dedicated specifically to swapping UZ engines into Toyota trucks and 4Runners |
#4 (permalink) |
I'll check on the reverse lights. Thanks
#5 (permalink) |
if you dont have manual hubs are you sure your 4wd is even working..chances are its not check vaccuum lines or the switch on the transfer case
__________________
91 pickup 22RE, 5 speed swap, 35x12.5 TriXuS M/T-SOLD! 96 4Runner Limited-FOR SALE! 07 FJ |
#6 (permalink) |
I have manual hubs, will check the transfer case switch and brake lights tomorrow.
Thanks Guys |
#7 (permalink) |
I have a 86 4runner I have no 4wd indicator light or reverse lights whats the likely fix and what should I be checking for???
__________________
99 SR5 V6 Auto 4WD, deck plate, TRD exhaust, Donahoes/Bilsteins,cornfed spacers, Waag Nerfs, Wet Okole's, Load warrior, Optima red top 86 Turbo SR5 4Runner (work in progress)(Money pit) |
#8 (permalink) |
__________________
#9 (permalink) |
on my 94 pickup all that was wrong was a wire in the top of the diff was broken. 4wd still worked but the light didnt work. fixed the wire and now have 4wd
#10 (permalink) |
Stick your head underneath the truck and look at the right side of the transmission near the transfer case. The indicator light runs off a switch in that area - my wires torn, so my 4WD light has never come on
Maybe one day I'll fix it...just don't see any reason to...
__________________
94' Pickup |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| brake light coming on | Robert m | 86-95 Trucks & 4Runners | 3 | 03-01-2007 06:23 PM |
| Engine light coming on, then off, then on again... | fo_runner | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 06-18-2006 04:43 PM |
| Dash Brake light coming on under braking along with batt light | DravisAR | Maintenance & Repair Archives | 2 | 07-25-2005 07:22 AM |
| Success: No 4WD Dash Light = No 4WD | Memphis4X4 | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 10-10-2003 12:40 PM |
| 4wd relay clicks and no light on dash...4wd engaged or not? | surferfrank | 95.5-2004 Tacomas & 96-2002 4Runners | 7 | 09-15-2003 12:26 PM |
