Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
2nd Gen Power Window Problem
hi guys i have a 94 4runner.
Both rear windows have been giving me trouble. At first they would slow down a lot (sometimes stop) half way up. Now, for the most part they don't even work. Sometimes they will go up but not down. I took the switches out and swapped them with a good switch and they still work intermitantly. I tested and it appears i still have power going to the window switch harness. Could the problem be the switch with the drivers door master switch setup? Does anyone know which terminals to connect directly to a battery to test the motor.
__________________
94 4Runner 3.0 5spd 31" BFG A/T Custom Bumper 150w KC Daylighters |
| Sponsored Links |
#2 (permalink) |
If you clean the master switch on the drivers door, it should help. it did with mine and even now mine still ****s up alot. my passenger window would not work at all unless there was some magic in the air (So never). i cleaned all the switchs out with compressed air that i use for the PC and some electical cleaner from GUNK and now only the master switch can work the windows. if the passenger uses it i have to do something to that switch to make it work.
__________________
-Phyl 1991 Hilux Surf SSR-G Petrol 3.0L V6 193,000kms l 3.4L V6 264,000kms to be rebuilt then installed! l Rancho RS5000 l 31"x10.50"xR15 Pro Comp Xterrain l K&N Drop in filter l PP 1" Lift Coil Springs l TRD shift knob l Lv. 3 First Aid Kit l White Gauges & Temp Controls l LED conversion l 80/100W Hella H4 l Hella Black Magic l 1st Gen Roll Bar Mod l FT/RR Diff. Breathers l Smittybilt XRC8 Winch l TOYOTA TOUR 2008 トヨタ|NEVER QUIT
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Odd Power window Issues 2nd gen | My99 | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 01-03-2008 04:35 PM |
| Yet Another problem with the 2nd gen rear window... | Belize Off Road Team | 86-95 Trucks & 4Runners | 1 | 11-06-2007 10:17 AM |
| 3rd Gen Power Window buttons in 2nd gen? | da_bigg_wigg | 86-95 Trucks & 4Runners | 4 | 04-20-2006 01:50 PM |
| 2nd Gen rear window problem? | grams72 | 95.5-2004 Tacomas & 96-2002 4Runners | 0 | 03-06-2005 01:53 PM |
| 2nd Gen Exhaust and rear window problem | tman6508 | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 06-03-2004 05:02 PM |
