2nd gen 4runner speakers - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > General Electrical & Lighting Related Topics
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-10-2009, 03:15 PM   #1 (permalink)
Well I've gone through plenty of posts, and it seems everyone who says they got a 6.5 into that rear OEM enclosure seems to forget pics
I'm about to pull the box and get some measurements before I head off to the store to see what's the largest I can in that thing. Does anyone have prove positive pictures of their rear speakers? I want it BEHIND the interior plastics.
mlrtime99 is offline
Old 10-10-2009, 04:39 PM   #2 (permalink)
JeEVeS's Avatar
x2
__________________
scheme'n
1994 4Runner SR5 22RE R151f hand built on the street. Now cruising at .4mph
Member since 08 but it took me 3 years to come up with an unasked question
Jeni
JeEVeS is offline
Old 10-10-2009, 05:39 PM   #3 (permalink)
RobD's Avatar
I did but don't have any pics. Simply put, I pulled out the enclosed speakers that were there. Be careful if you have the ones that are amplified, since cutting the power with side cutters could be a bad idea.
With a piece of cardboard, I made a template and transferred that to a piece of 3/4" MDF and made backing plates for my new speakers. I cut out the hole for the speakers in the backing plates, screwed them to the flange that you have near where the old ones mounted up and oingo boingo, new rear speakers.
__________________
1991 4Runner, 3.4 5VZFE swap, OME shocks/springs, 33" BFG All Terrain T/A KOs, Pioneer head unit, Infinity speakers, XM Satellite radio
RobD is offline
Old 10-10-2009, 10:22 PM   #4 (permalink)
So did you keep the factory enclosures or just go free air?
I'm am big on enclosures, Crutchfield used to make these poly foam baskets that worked great for odd spaces.
I did the rears tonight, 6.5". Removed the OEM "pods" angle grinder with a grind and sanding disk to make the surface flush and resized the hole. Then surface mounted the new speakers. Nothing too special but I took a ton of pics and I'll get them up for you guys tomorrow.
The most important thing when you're resizing the hole is to stay away from the factory port without moving towards the front of the car too much (the speaker surround gets close to the sheet metal (as someone noticed in another thread).
P.S. cheap speakers but holy CRAP the 4runner sounds great after getting rid of those 19yr old speakers.
Old 10-10-2009, 11:41 PM   #5 (permalink)
RobD's Avatar
I went free air, though I suppose I could build a small enclosure behind them, it wouldn't serve much of a point. It's not like I'm trying to run a sub there or anything. They're just for rear fill.
__________________
RobD is offline
Old 10-11-2009, 12:55 AM   #6 (permalink)
70elcoss's Avatar
Send a message via AIM to 70elcoss
yeah you are going to have to cut it open more, when i got mine, it already had aftermarket 5.25" inch infinty kappa speakers but they sucked so i swapped them out for some 6.5" TMA's. all i did was take a file and trim and make the opening bigger
oh and for the drivers side, you might have to trim that metal part of the body in the picture cuz it is very very close to the speaker cone and doesnt leave a lot of room for flex, i havent trimmed it yet but really need to. the passenger side theres no metal that comes close to the box, but everything is a tight fit with the 6.5's, it works, you just have to make it fit somehow.
__________________
Daily driving 1990 4runner
2door
31" pro comp all terrain
3.slow v6
rebuilt 5speed tranny and t-case
2 12" audiobahn subs and 700 watt orion cobalt amp
magnaflow exhaust
over 213,000 miles and counting
70elcoss is offline
Old 10-11-2009, 12:51 PM   #7 (permalink)
runnermedic's Avatar
Send a message via MSN to runnermedic
hi pal!
here are the pics you want ,i did mine today with 6.5 speakers ,keep and eye on the metal panel i fits but is to close to the speaker surround so take a plier and pull back a little the metal so it wont rub your speakers,you need to use some sealant like hot glue or silicone to make the speaker holes more air tight.you will be satisfied with the sound it will be more clear and the bass will be more clear too.
enjoy!!!!
2nd-gen-4runner-speakers-img_0047.png   2nd-gen-4runner-speakers-img_0051.png   2nd-gen-4runner-speakers-img_0053.png
runnermedic is offline
Old 10-11-2009, 01:50 PM   #8 (permalink)
James Dean's Avatar
The main thing on small speakers is to keep the front and back wave from joining. So as long as the speaker is mounted in the side panel you should be fine. I doubt mounting it in the box will provide any benefit. Besides the boxes the factory designed are for low throw speakers that are tuned for low frequencies. The tweeters above the rear window provide the hi-s in the rear.
Not saying it shouldn't be done, just not all that important.
__________________
Custom painter and Toyota Stripe and decal supplier.
http://jamesdeancreations.com
Custom Safari and Crawlin accessories.
http://www.jamesdeancreations.com/4runner_project.htm
James Dean is offline
Old 10-11-2009, 02:32 PM   #9 (permalink)
James Dean's Avatar
I removed my factory rear boxes and mounted my new 5" component speakers in my new side cabinets. I installed the tweeters where the factory tweeters were mounted. The one side cabinet holds my sub the other my air pump and 2nd battery. The boxes will get trimmed to cover and hide it all. The interior side panels will be cut to the boxes and then re-intalled.
The black carpet will be grey. Just had some black laying around.
__________________
Old 10-11-2009, 03:34 PM   #10 (permalink)
Send a message via MSN to Birdbrain
Holy shiniza! James Dean! Thats a brilliant idea... lol...
Looks like i might be copying you...
Birdbrain is offline
Old 10-11-2009, 06:31 PM   #11 (permalink)
RobD's Avatar
My only observation about James' creation is that it eats up a ton of rear real estate. That's all I'm saying.
__________________
RobD is offline
Old 10-11-2009, 06:37 PM   #12 (permalink)
You know, i dont think it does that too horribly, as it seems to be built around the wheel wells so that its more square is all. then again, having my rear's real estate more square would be a + to me so... haha
Old 10-11-2009, 06:52 PM   #13 (permalink)
James Dean's Avatar
They are tapered to match the wheel wells. It doesn't look like it, but tapers 3" at the rear. They are full of items. Subs, amps on both sides, battery, air pumps and power inverter. All of it stays hidden and protected.
__________________
Old 10-13-2009, 09:11 PM   #14 (permalink)
I got some 6.5" pioneers from my brother in law (new in packaging!!! )
so I took the old boxes out... dremeled the whole larger... insert pioneers... replace box... no rubbing, fit and sounds great!
and myself fighting the carpet and siding back together...
I like it!
Old 10-13-2009, 09:22 PM   #15 (permalink)
camo31"10.50"'s Avatar
but what about the front you guys?!?!?!?!..the rear is rather simple in my opinion..but the front is a little more complicated..i want to put 6.5's in the door..guess i'll have to cut the panel
anybody got any pics of their front speakers!?!
__________________
FOR SALE 1986 Ext. Cab 4x4, rebuilt 22R, 5spd, 31x10.50 X-Terrains FOR SALE
1992 SR5 FO RUNNA V6, 5 speed, 4in. trail-master lift, 33x12.50 BFG muds, 4.56 gears!!! and an IMMACULATE interior..yes..you should be jealous
"Its still a toyota man.. Dont deprive it of its capabilities.."
"If you can read english, Thank a teacher...If you can speak it, Thank a soldier!!" Kelli Ruark-2009
camo31"10.50" is offline
Old 10-16-2009, 09:11 AM   #16 (permalink)
Crap I forgot to put these up! I was going to fiberglass the front of the enclosure to seal all the holes but then realized the Michigan game was on so it got cut short. I used Pioneer TS-G's they fit perfectly, nice low surround. The fronts were just upgraded to new 4", I'll have to do something in the door, that space is impractically small.
I did loose the mounting bracket for the electrical connector on top, no big deal just made a new one out of gaffing tape. When you're enlarging the hole go AWAY from the factory port.
2nd-gen-4runner-speakers-1.jpg   2nd-gen-4runner-speakers-3.jpg   2nd-gen-4runner-speakers-5.jpg
Tags
1992, 2nd, 4runner, 87, back, door, factory, forum, gen, generation, rear, speaker, speakers, specs, tweeters, yotatech
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
