YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > General Electrical & Lighting Related Topics
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 06-14-2008, 12:46 PM   #1 (permalink)
hurley842002's Avatar
1st gen 4runner/2nd gen pickup marker light blinker mod
After putting a new bumper on my 4runner and having to drive around with my turn signals zip tied to my grill, I decided something needed to be done. I searched a couple of the marker light blinker mods on here and other places, but most of them seemed to be used as a secondary turn signal using the original bulbs and wouldn't be nearly bright enough to be used as a primary turn signal, so this is what I did.
first purchased a universal bulb socket from pepboys that would accept an 1157 dual fillament bulb.
I used a 1 litre aquafina bottle cap per side as a spacer (to be able to fit the 1157 bulb) and it fit perfectly in the half circle piece of plastic that surrounds the original hole. I also had to enlarge the original hole. I used some plastic weld to hold the bottle cap and seal everything up.
Cut the bottle cap to accept the socket, if you cut exactly along the outer edge of the writing on the cap, it fits perfectly for this particular application.
Here is the wiring, I just used the original plug.
Here is the finished product, ready to be installed. The socket is easily removable for bulb replacement.
Sorry for the crappy pics, they are just cell phone shots, I hadn't planned on doing a write up, but it turned out better than I thought and was really easy so I thought I would share. This may not be for everyone, as it eliminates your marker lights, but as a clean solution when your bumper will no longer accept the factory turn signals it works great.
__________________
1986 4runner
31" mt's
aftermarket shackles
Custom front bumper/winch
Light bar/auxilary lighting
Rear Detroit
future mods:
33's maybe 35's, 5.29's, Rear bumper with tire/jerry can,highlift mounts, sliders. Conquer with the IFS until I can't conquer anymore and then do an SAS.
hurley842002 is offline
Sponsored Links
To remove this ad, register today!
Old 06-14-2008, 01:05 PM   #2 (permalink)
Looks Good. How do those sockets stay in place? Do they pop in and out or do they twist?
__________________
Just dropped in to see what condition my condition was in.
pyro is offline
Old 06-14-2008, 01:49 PM   #3 (permalink)
4Crawler's Avatar
I did the same thing about 10 years ago:
- http://www.4crawler.com/4x4/CheapTri...rnSignal.shtml
My socket was spring loaded with a mounting plate, so I put those two together and silicone sealed that together and then just screwed the plate to the back of the housing:
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs.
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 06-14-2008, 05:28 PM   #4 (permalink)
Quote:
They pop in and out. I suppose if you had to remove them regularly they may be a bit of a PITA but once every several years or so shouldn't be too bad.
__________________
1986 4runner
31" mt's
Rear Detroit
future mods:
Old 06-14-2008, 05:33 PM   #5 (permalink)
I like that set-up. You didn't have any problem with the bulb making contact with the lens? I've looked at quite a few of your cheap tricks, I guess I overlooked that one.
__________________
1986 4runner
31" mt's
Rear Detroit
future mods:
Old 06-14-2008, 06:19 PM   #6 (permalink)
BigBluePile's Avatar
Send a message via MSN to BigBluePile
I did this:
http://www.4x4wire.com/toyota/tech/tacoma_turn_signal/
but for my '86 4Runner.
__________________
Logan Oliver
'86 4Runner SR5 22R-E
Complete engine overhaul at 175,000
4" Procomp/Superlift/Rancho 9000x
Downey Header/Magnaflow exhaust
315/75R-16 Baja Claws wrapped around AR-23's
4.88's a TrueTrac and All Pro rear disc kit w/emergency disc trans brake
BudBuilt skids
'06 4Runner Sport
270/65R17 BFG All Terrain KO's
BigBluePile is offline
Old 06-14-2008, 06:30 PM   #7 (permalink)
Wow, apparently I didn't do enough searching. Oh well I guess its better to fab up your own stuff anyway.
__________________
1986 4runner
31" mt's
Rear Detroit
future mods:
Old 06-15-2008, 07:24 AM   #8 (permalink)
Quote:
Heck no!! I liked how you used the water bottle cap! In order to get those 1157 bulbs into my marker lights I had to use lots of bondo and put the bulb in at a wierd angle. Whatever works!!
__________________
Logan Oliver
BudBuilt skids
'06 4Runner Sport
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Trade 1st gen 4runner for 2nd gen pickup hurley842002 Vehicles - Trailers (Complete) 10 04-25-2008 12:47 PM
WTB:Vent windows for 2nd gen pickup/1st 4runner cunninglinguist Items Wanted 1 04-11-2008 05:22 PM
Wanted Passenger Side 2nd Gen Marker Light Dare44 Items Wanted 2 10-07-2007 04:45 PM
1st gen 4runner top on 2nd gen pickup? EWAYota General Vehicle Related Topics (Non Year Related) 2 06-02-2007 11:55 AM
1st Gen Bed on 2nd Gen Pickup? Bill 86-95 Trucks & 4Runners 4 01-08-2007 06:25 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
