General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
1983 pickup alternator not working
Old 06-08-2013, 02:49 PM
tRod's Avatar
the alternator is out of an 86 model so the wires arent quite the same it seems like, and when i hooked it up it started but when i took the negative battery terminal off it quit. i realized the 86 alternator is internally regulated so i took the old regulator out of the loop and then when i started it it would crank but it would shut off and if i revved the engine i could get it to keep running...i think the problem lies with the sense and light wires, but i cant seem to figure out how to fix it. anyone got any ideas?
Old 06-10-2013, 07:12 AM
tRod's Avatar
now i got it to stay running well but when i disconnect the battery it stops again..
Old 06-10-2013, 02:59 PM
wyoming9's Avatar
Red face
I am sure lots of people swapped to the newer alternator.
Where do you have the wire going from the B terminal of the alternator.
Do you have a Red Yellow and white wire in the round plug I am looking at a 87 22REC
Old 06-15-2013, 12:42 PM
tRod's Avatar
the B terminal is the seperate one that is white and larger than the others right? if so then it goes into the wiring harness and i havent traced it any farther than that. when i got it there was no round plug but i know what you are talking about im trying to find one to buy, anyways there is a yellow a green and a white with a black stripe that go to the alt. i believe i have them on the right posts at the terminal, but since the color codes are different for the years im having trouble finding which wires go where and how to find out without completely tearing the wiring harness apart...
lledwod
09-06-2016 07:33 AM
bigblue82
10
07-06-2015 08:27 AM
gog1968
06-22-2015 05:55 AM
paxanders
06-21-2015 06:29 AM
Land yacht
06-28-2002 09:53 AM
Quick Reply: 1983 pickup alternator not working
