Airbox Modification For The 3.0 V6 Engine - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Tech Write-Ups (Staging Area & More Articles In The Wiki) > Performance Enhancements
Welcome to Yotatech!
Welcome to Yotatech,
Closed Thread
Old 12-31-2005, 12:46 AM   #1 (permalink)
Airbox Modification For The 3.0 V6 Engine - 5/23/2003
Joey (UKMyers on the forums) shows you how he modified the stock air filter airbox so it will let in more air flow for more performance.
Tools Required:
10 and 12 mm sockets, Drill, ¼” bit
Time Required: 45 minutes
This mod is pretty simple to do but before even considering it you must consider your type of driving. If you're the type of off-roader that likes to Kamikaze through huge mud holes this mod is NOT for you. If you off-road and go through mud and water carefully or do mostly street driving then read on.
The whole point of this mod is to make your engine breathe a little bit easier for a whole lot cheaper than the FIPK kit by K&N. The first step is to remove the spoiler that is right behind the drivers side headlight. There are (2) 10mm bolts that hold it in.
Once the screws are out to remove it you'll have to remove the radiator overflow bottle which is held in place by a bracket and (1) 10mm bolt.
Just lift the bottle out of the way and the spoiler should come out. You will have to wiggle it around, as there's a tube that attaches it to the airbox. Pull out the spoiler and the tube attached to it.
You can stop here or you can get a bit more airflow by drilling out the bottom of the airbox, which is what I did. To remove the airbox you'll first have to pull the top part off where the Mass Airflow Sensor is.
You'll have to remove the big tube that comes from the throttle body to airbox at the airbox side or you'll never get the top off.
Make sure your engine is warm and loosen the 10mm bolt on the clamp that holds the tube. You may have to coax it loose if it's been on there a while. Once you get that tube removed, you can gain access to your air filter by popping the three clips that hold the top half of the airbox to the bottom half. If you don't have a K&N drop in I highly recommend getting one.
At this point you'll have one more small box bolted to the lower half of the airbox with two more 10mm bolts. Remove that sucker and all that's left are (3) 12mm bolts that hold the bottom half of the airbox to the fender.
Take them out and you can pull the rest of the airbox out to drill it. I used a ¼” bit and only drilled half of it but you could get as radical as you wanted to.
You can see my box that is drilled and also Chris Hearn’s airbox in the 3rd picture where he cut the whole bottom off his!
Once your done drilling make sure you use a knife or something to ream out the holes to remove any plastic shavings that may have been left behind. I would also take this opportunity to clean everything in the airbox really good.
Put everything back together minus the spoiler and tube and fire her up and listen to your new rumbling airbox. If you floor it you can really hear it sucking it sounds pretty cool!!
I noticed right way better throttle response and bit more torque. Engine seems to have less trouble getting to the power band now. Overall pretty simple mod to do. Just keep in mind though that your airbox is now a bit more exposed than it was. It is still nothing close to being as exposed as the filter in a FIPK kit though! If you choose to do this mod good luck, and if you have any questions PM UKMeyers
Bob_98SR5 is offline
Closed Thread
Tags
3, 30, 4runner, air, airbox, bottom, box, coming, do, engine, half, mod, modifications, remove, tube, yotatech
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Engine Swap- 3.0 L V6 duck trapper 86-95 Trucks & 4Runners 5 01-19-2007 01:05 PM
4.0 v6 engine oceanworker 95.5-2004 Tacomas & 96-2002 4Runners 3 05-02-2004 04:50 PM
Airbox mod on 95 3.0L V6? Raptor 95.5-2004 Tacomas & 96-2002 4Runners 6 10-14-2003 07:25 AM
Need a Price and V6 engine help jkirk 95.5-2004 Tacomas & 96-2002 4Runners 0 06-29-2003 10:15 AM
engine swap; 94 V6 to 96 or newer V6? base554 95.5-2004 Tacomas & 96-2002 4Runners 13 02-14-2003 09:49 AM
2009 InternetBrands, Inc.
