York On-Board Air fitted to a 22RE - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Tech Write-Ups (Staging Area & More Articles In The Wiki) > Off Road Enhancements
Welcome to Yotatech!
Welcome to Yotatech,
Old 01-08-2009, 12:20 AM   #1 (permalink)
Matt16's Avatar
I fitted a York OBA system recently. Here it is:
Discussion on this topic can be found here: http://www.yotatech.com/f116/22re-yo...mplete-155162/
and more info on the bracket can be found here: http://yotatech.com/f116/york-air-co...r-22re-152143/. I must warn you though, that I build a bracket as per instruction off PirateBB, and it didn't fit, the one below I designed and it actually works on a stock 22RE with OEM-height engine mounts.
Used these sites when figuring out my OBA:
http://www.jedi.com/obiwan/jeep/yorkair.html
http://www.mudinyerioffroad.com/yorkOBA.htm
I recommend doing this mod to your compressor as well so your compressor oil doesn't spill out down the air line.
http://www.jedi.com/obiwan/jeep/york_oilmod.html
On finding the compressor:
http://www.links4jeeps.com/writeups/...ork_Donors.php
Compressor: Full-sized York off a Volvo (I think, I bought it from a guy who had it in the garage)
Bracket: Adapted from a 22RE A/C bracket, you need a sort of spacer as well
Air lines: 3/8"
Air tank: Air brake tank off a Ford dump truck (note: not a dumpy Ford truck)
Valves switches etc: One-way into the tank, 150psi pressure release valve, drain valve, 90psi on/120psi off
Description:
  • York is belt driven off the engine in place of the stock AC pump (you can't install the York like I have with AC)
  • pressured air goes down the air line, through the one way valve
  • pump has a magnetic clutch that is activated by a relay
  • relay is only thrown when:
    a) the day-time runnning lights are ON (always on when engine is running (Canadian spec)
    b) the switch in the engine bay next to the quick disconnect is ON
    c) pressure is below 90psi.
  • air tank link to quick disconnect zip-tied near battery
  • fills up a 31" tire from ~5 to 35psi in ~30 seconds at 2500rpm
cost estimate
  • York compressor...................<$50
  • 22RE A/C bracket....................$30
  • 25' air hose, cut inot pieces......$15
  • NPT fittings............................$50
  • air brake tank........................$50
  • air filter, pressure valves.........$40
  • electrical bits.........................$50
  • TOTAL................................~$300 (based on what I actually spent)
  • Knowing your compressor pumps out 10X more air and costs less than half of the guys with a Viair....Priceless
more info: http://www.yotatech.com/f116/york-ai...r-22re-152143/
Here's the measurements on the bracket.
Looks like this when you're done.
I secured the bracket to the body of the truck.
__________________
1990 Toyota 4Runner 22RE 5spd
*Aussie Locker*York OBA*
Quote:
Originally Posted by DaveInDenver View Post
Yeah, I do think it's sort of funny. Can't you see a roomful of Toyota engineers looking at a relay rod, scratching their heads and saying 'Hmmm, this part wore out after 200,000 miles and 16 years, this is just unacceptable.'
Quote:
Originally Posted by DeathCougar View Post
next time when the front of your engine sounds like a can of spoons, fix it
Toyota FAQ link
More info on 4Runners
Matt16 is offline
Tags
210, 22r, 22re, ac, air, board, bracket, compressor, install, installation, lines, oba, onboard, toyota, york
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
22RE- York on board air COMPLETE Matt16 86-95 Trucks & 4Runners 41 11-01-2009 09:10 PM
York air compressor, 22RE Matt16 86-95 Trucks & 4Runners 62 09-30-2008 08:29 PM
On-board Air - Who has it? s.c.i.e.n.c.e 86-95 Trucks & 4Runners 44 09-27-2008 06:03 PM
York air compressor Ric General Vehicle Related Topics (Non Year Related) 3 01-25-2006 12:32 PM
Air tank for on board air mtnbkr Offroad Tech 2 05-05-2004 06:42 PM
2009 InternetBrands, Inc.
