Rear Differential Breather Mod - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Tech Write-Ups (Staging Area & More Articles In The Wiki) > Off Road Enhancements
Welcome to Yotatech!
Welcome to Yotatech,
Closed Thread
Old 01-07-2006, 07:38 PM   #1 (permalink)
Robinhood150's Avatar
Send a message via AIM to Robinhood150
Jackson (jacksonpt on the forums) shows you how he hooked up his rear differential breather for safer water crossings.
Extending the rear diff breather line is a must-do mod. It's cheap, easy, and quick and requires next to no mechanical expertise. It cost me all of about $20 and 30 minutes of my time. I ordered 2 parts, a union fitting used as an intake manifold fitting (part number 90404-51319) and a small breather plug (part number 90930-03136) from toyotaparts4u.com for about $12 shipped.
I also picked up about 6 feet of fuel line for about $6, and a 4-pack of small hose clamps for $2. Both came from AutoZone.
I dropped the spare tire to give myself some room to work (it's kinda funny... with my lift, and the rear tire dropped, I can sit up straight underneath my rig-I think it's funny anyway). I used a small adjustable wrench to remove the old breather filter, and replaced it with the union fitting. I then attached one end of the fuel line to the fitting, and secured it with a small hose clamp. I ran the hose along the brake line and up the gas tank fill tube, leaving a little extra slack to allow for axle drop.
I used zip ties to secure the hose. I then opened the gas hatch and removed the rubber fitting around the fill tube (NOTE: do not try to loosen the nut for the release latch.
There is a tension cable used to control the latch that is easily dislodged-I know from experience. The tension cable can be re-seated, but it's tight working in there.). I fed the hose out through the opening and attached the new breather plug and used another hose clamp to secure it. I then ziptied the hose to the fill tube to prevent and rattles.
Breather Plug (part #90930-03136)
Union fitting (part #90404-51319)
__________________
Steve. '93 4Runner V6 Auto 4x4
Robinhood's Lair. || Gettin' Off 4wd Club member
Lots for sale:5.29 ARB IFS third member... Click
Sierra Club policy: [A reason to close trails] ...Physical soil damage, often readily visible, resulting in:
a. Erosion, causing soil loss and damage to stream banks, streams, and fish habitat...
Lesson...Stay on the TRAIL!
Robinhood150 is offline
Closed Thread
Tags
4runner, beather, breather, breathers, connector, diff, differential, end, hose, kit, mod, rear, sale, tube, yotatech
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Rear Differential Breather? Chrisnxl185 86-95 Trucks & 4Runners 19 12-07-2007 12:34 PM
Rear Differential Breather rearviewmirror 95.5-2004 Tacomas & 96-2002 4Runners 2 12-19-2006 11:47 AM
For Those Who Are Going To Do The Differential Breather Mod.... fireteacher 95.5-2004 Tacomas & 96-2002 4Runners 11 04-17-2006 06:56 AM
Differential Breather Mod w/pics rimpainter.com 95.5-2004 Tacomas & 96-2002 4Runners 17 03-10-2003 07:05 PM
2009 InternetBrands, Inc.
