Are you tired of tailgate rattle with your 84-94 Truck? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Tech Write-Ups (Staging Area & More Articles In The Wiki) > Maintenance & Repair
Sign in using an external account
Register Forgot Password?
Maintenance & Repair Care and feeding of your rig
Welcome to Yotatech!
Welcome to Yotatech,
LinkBack Thread Tools Search this Thread
Old 08-28-2011, 12:24 AM   #1 (permalink)
Personal Sales Rating: (0)
Send a message via AIM to john4wd Send a message via Yahoo to john4wd
After a while your rubber inserts under the striker gets squished/looses it rebound to hold the latch tight and the 2 loops that are used as springs get deformed as well.
If you are tired of the rattle and want a cheap fix here is one, you can go get new ones but they will do the same as old ones in a few years, or you can do my mod and it'll last forever.
1st removed the 2 bolts holding the strikers...
2nd disassemble the parts
3rd here are the parts and how too do it.
Go get or find lying around pusher spring like this one, was longer but was cut shorter for mod, one with a flat side to go against the metal part above the rubber piece, cut side against the rubber.
Spring goes in between the 2 rubber loops sticking up.
This metal strap goes above the rubber part and the new spring.
It'll look like this.
Put all the pieces back together and put them back on either of the bed sides and adjusted it so tailgate when closed will be flush, after I did this tailgate barely moves.
Ps. Small pusher spring from pens will not work, need springs as wide as space between the rubber loops. Have fun!!!!
__________________
My build thread below, Check it out!!!!
http://www.yotatech.com/f199/john4wd...thread-240344/
john4wd is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiTweet this Post!
Yotatech
4WD Truck
Paid Advertisement
Tags
adjust, gate, latch, net, ratteling, rattle, tail, tailgate, toyota, truck, yotatech
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Contact Us - YotaTech - Archive - Top
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
2010 InternetBrands, Inc.
