solution to brake light Ebrake lamp ! - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Tech Write-Ups (Staging Area & More Articles In The Wiki) > Maintenance & Repair
Welcome to Yotatech!
Welcome to Yotatech,
Old 07-20-2009, 07:45 AM   #1 (permalink)
trythis's Avatar
trythis:
When you have refilled your master cylinder, replaced or checked out your e brake switch under the dash and you brake light just stays on, I have a solution to prevent having to buy a new reservoir sensor cap for $100 plus by cleaning it out.
If the float makes a little click and the brake! light dims and brightens when you are doing this you have fluid in the float switch.
Gouge out the resin around the wire under the rubber cap. ( you have to pull the rubber cap off the white plastic.
Gently pull the magnetic switch and resistor out and clean out the stem of the float.
Test the float on the vehicle out of the brake reservoir so you don't get it all wet again.
It will probably work, and if it does you need some sort of brake fluid resistant goo to seal the top of the stem with. (I chose CRC brake quiet used for brake pad silencing in a red glue bottle. I hope it works. It dries like silicone and has ethylene glycol in it , which may or may not be brake fluid safe...)
Shove the sensor back into the stem, add your goo, and reassemble.
If the goo has acetic acid (silicone that is not made for aquariums always does.), it might eat the tiny little circuit board (if you want to call the phenolic oval that the sensor uses to hold the parts in place with a circuit board.
Sorry no pictures.
__________________
89 DLX xtra cab 4x4 22re Auto with 210,000, 225 75R 15, Stock except, "new" 2000 toyota cd/radio, rear speakers hidden in the back seat, SR5 instrument cluster, factory clock. dead aftermarket cruise and some matching blue door pockets! New timing chain with Engine builders front end rebuild kit. Tokico RT trekmaster shocks <-like them.
I found the turtle in my yard, after mowing over it and it was fine! Old toyota trucks are like turtles: slow, steady and durable.
trythis is offline
Tags
brake, float, switch, toyota
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
