Light Replacement for the Heater Control & Glove Box - 2nd Gen 4Runner - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Tech Write-Ups (Staging Area & More Articles In The Wiki) > Maintenance & Repair
Welcome to Yotatech!
Welcome to Yotatech,
Closed Thread
Old 01-14-2006, 09:58 PM   #1 (permalink)
Heater Control Light/Glove Box Light Replacement - 2nd Gen 4Runner (Also for 89-95 Trucks)
By L33T35T
Jason (L33T35T 4Runner on the forums) shows you how to replace the dash light behind the heater controls. This fix is for the '90 to '95 4Runners, and the '89 to '95 trucks.
HEATER CONTROL LIGHTS
Tools needed:
Your fingers
Paper clip, small item to slip in behind the panel and pull out
Sylvania # 74 bulb
1. Remove the four knobs from the slider controls.
2. Using any flat utensil (paper clip works great) pry the face plate off... it seems fragile... and CAN break... but it's quite flexible.. to a point. at this time the A/C button comes out.
3. Front face removed.
4. Picture is of removal of magnifier thing for the light... simply pull back clip with one finger (on right side) and pull out unit with small screw driver or finger from top.
5. Magnifier. removed.... bulb exposed. you can simply pull it out with your hand. Do not lose the bulb condom as the dealers don't have them. You would have to scour the junk yards, or buy them from AutoMeter. They are on their website, but you will have to hunt for them, no direct linking.
The part # for the bulb is a Sylvania 74 at most auto parts stores for under $1. You can also get it at the dealer, and the part # is 09081-11018, but they run around $2.63 or more each.
GLOVE BOX LIGHTS
Tools needed:
10mm socket
Phillips screw driver
1. To remove the glove box light, unscrew the 10mm bolt bottom right of glove box, unscrew 3 screws inside top glove box.
2. Close the glove box closed. Unscrew the last screw on the bottom left outside glove box. Support bottom of dash with hand, open glove box. let hang, and you should be able to see the bulb.
Bob_98SR5 is offline
Closed Thread
Tags
1994, 2006, 4runner, 74, 88, ac, box, bulb, control, glove, heater, light, lighting, plate, remove, sylvania, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Glove Box Light Rivalred 03+ 4Runner/GX470, & 05+ Tacomas 8 11-06-2005 06:18 PM
No light in glove box,cigarette lighter ring or ash tray EOD30 95.5-2004 Tacomas & 96-2002 4Runners 10 10-21-2004 07:43 PM
Glove box light...need some help Phisherman 95.5-2004 Tacomas & 96-2002 4Runners 1 08-02-2004 06:30 PM
2009 InternetBrands, Inc.
