Ford horn in 87 pick-up - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Tech Write-Ups (Staging Area & More Articles In The Wiki) > Electrical
Welcome to Yotatech!
Welcome to Yotatech,
Old 12-29-2008, 12:38 PM   #1 (permalink)
First remove the grill to get to the stock horn. it should be on the passenger side.
I used a piece of back strap i had laying around. Any strip of metal should work. I had to drill bigger holes in it to mount the horns.
Find a place to mount them so that they don't hit anything. I had to tweak it just a bit so that it wouldn't hit the grill.
I used these crimp on connectors so i didn't have to cut the stock plug off. The blue was + and the green was -
You have to wire up a relay. The ford horn grounds to the frame, if you mount these to the frame and hook up the + the horn will stay on. I wired my relay like this.
86 ground on the stock harness (the green wire)
85&87 positive on the stock harness ( the blue wire)
30 positive on the horn itself
Hope this helps someone get rid of their stock dinky horn. Here is it all finished.
deez92 is offline
Tags
33, ford, horn, yotatech
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Horn hopper 95.5-2004 Tacomas & 96-2002 4Runners 9 09-02-2008 11:41 AM
Help me pick out a horn setup for the pickup.... Tacoma750 86-95 Trucks & 4Runners 18 09-25-2007 12:00 PM
Ford Quits Ford BT17R Off Topic Talk 24 09-22-2006 06:17 PM
Need some horn help. FSRBIKER 95.5-2004 Tacomas & 96-2002 4Runners 4 06-09-2004 02:17 PM
Ford Exec Says Toyota is better than Ford . . . DrummerDaveB Off Topic Talk 7 02-14-2003 03:01 PM
2009 InternetBrands, Inc.
