Flex-A-Lite Fan Wiring - FLX165 - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Tech Write-Ups (Staging Area & More Articles In The Wiki) > Electrical
Welcome to Yotatech!
Welcome to Yotatech,
Old 01-11-2007, 10:53 AM   #1 (permalink)
Tech Article Editor
Writeups@YotaTech's Avatar
Article By:
jsnby
Application Vehicle: 1992 4Runner, 3.0L V6
When I installed my FLX-165, I ordered the optional cut-off switch that was advertised to be able to turn off the fan for mud and water crossings.
I was disappointed when, after following Flex-A-Lite?s wiring instructions, the switch did not turn the fan off, but turned the fan on.
This was unacceptable.
Parts:
FLX-165
Buss Aux. Fuse Block (Part # BP/15600-06-20) (optional but highly recommended)
12V 40A SPDT relay (Jameco Part # 148582)
Flex-A-Lite switch (or any 3 terminal lighted switch)
Make sure you get a SPDT relay or a normally closed SPST relay.
The reason is that you don?t want to have to have the switch turned ?on? for the fan to work normally.
This would constantly drain current(~50-100mA) from your battery.
The way the circuit works is that when the switch is in the ?off? position, the fan is supplied power.
When the switch is in the ?on? position, the relay disconnects the power to the fan, thus shutting it off.
Leave the terminal marked ?87? open (ie. Don?t connect it to anything).
Any questions about this article, please contact jsnby, and not Writeups@YotaTech
__________________
Greetings, this account may not be the author of this tech writeup, so please contact the author of the article for more information.
So please do not contact me, I am only putting the authors article here.
This account does not accept email or PMs.
Contact Corey for info.
Writeups@YotaTech is offline
Tags
165, 4runner, 89, controller, fal, fan, fans, flex, flexalite, lite, manual, relays, switch, turn, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Flex-a-lite fan 1Runner 95.5-2004 Tacomas & 96-2002 4Runners 23 08-29-2005 06:53 PM
Flex fan question. NOT flex-a-lite/electric fan hockeytown9 95.5-2004 Tacomas & 96-2002 4Runners 4 02-12-2005 03:34 PM
Flex-a-lite fan Murph 95.5-2004 Tacomas & 96-2002 4Runners 4 06-28-2003 05:18 PM
flex-a-lite fan boss hog 95.5-2004 Tacomas & 96-2002 4Runners 9 03-24-2003 05:19 PM
2009 InternetBrands, Inc.
