Please note that the email server is about 1 to 2 hours behind, so please do not create a second account while waiting for your registration letter to arrive
Welcome to Yotatech!
Welcome to Yotatech,
Well ventilated area
Stay away from open flames while painting
Follow manufacturer recommendations for removing wheels/tires
Organic vapor respirator
Safety glasses
Gloves
Electric drill
3" Wire cup brush (fine)
Sand paper (100 - 200 grit)
Newspaper
Durable painters tape (if tire is on the rim)
Paint thinner or acetone
Clean rag
Quick-drying automobile primer
VHT Polyurethane Wheel Paint (ideal, use 2 coats)
Dupli-color High-temp Engine Paint (optional to VHT, use 2 coats)
Dupli-color clear Wheel Coating (optional, but recommended, use 2 coats)
Lug Nuts
Follow the same instructions for the wheel if you want to paint the lug nuts.
It should be noted, however, that powder-coating is recommended for lug nuts since,
generally speaking, they see much more wear than a wheel over time.
Wheel Weights
Hand sand and wipe wheel weights with acetone or paint thinner. The primer step can
be skipped for wheel weights. Paint can be applied immediately after quick-prepping
the weights.
Center Cap
Follow wheel painting instructions for the center cap.
Inside of the Wheel (back side)
Same prep and paint rules apply for the inside of the rim/wheel. Be sure to remove all
rust prior to priming/painting. Please note: On most wheels, the inside of the wheel is
difficult to see when mounted, therefore painting it is usually a waste of time and money.
Clear Coat
Clear coat is recommended. However, it will make the wheel glossy (although the gloss uniformly fades
over time).
Touch Up (rock dings, scrapes, lugs, etc)
Clean and dry the wheel.
Apply a uniform layer of paint using the original color and type.
Big Problems
In the unlikely event that you mess up painting a wheel (for example a drip forms), simply lightly grind/sand
down the effected area, wipe the entire wheel down with paint thinner or acetone again, and re-apply the paint.
If the area cannot be fixed, repeat the wheel prep and painting process from step one.
Christian has chosen to include a step by step video here.
The video is hosted on You Tube.
Click the picture to view it.
Once there, you can also watch the video full screen by clicking the far right button on the player.
The video is also embedded on this page here if you would like to view it inline with Christian's text above.
Any questions about this article, please contact <96 Runner>, and not Writeups@YotaTech
This ad is not displayed to registered members. Register your free account today and become a member on Yotatech!
__________________
Greetings, this account may not be the author of this tech writeup, so please contact the author of the article for more information.
So please do not contact me, I am only putting the authors article here.
This account does not accept email or PMs.
Contact Corey for info.
