Painting Chrome Wheel Well Trim to Black - 3rd Gen 4Runner - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Tech Write-Ups (Staging Area & More Articles In The Wiki) > Appearance
Sign in using an external account
Register Forgot Password?
Appearance Appearance, interior enhancements
Welcome to Yotatech!
Welcome to Yotatech,
Closed Thread
LinkBack Thread Tools Search this Thread
Old 01-08-2006, 10:38 PM   #1 (permalink)
Personal Sales Rating: (0)
Repainting Your Chrome Wheel Well Trim to Black - 3rd Gen 4Runner
By <96 4Runner>
Christian (<96 Runner> on the forums) shows you how he painted the factory chrome wheel well strips black on his 3rd gen.
Tools Required:
None
Supplies:
1. Premium Rust-Oleum Automobile Primer Spray Paint (Home Depot)
2. Rust-Oleum Painters Touch Black Spray Paint
3. Clear Top Coat Spray Paint
4. 100-grit sand paper
5. Painters Tape (masking tape will work also)
6. Paint Thinner, Acetone, or Goof-Off
7. Old shirt or clean rag
8. Newspaper (over-spray protection)
9. Old sheet (to cover wheels and tires)
Start by cleaning the fender trim thoroughly with Paint Thinner (or similar).
It is important to ensure the tape has a clean surface to bond to. Directly wipe the chrome piece, slightly overlapping onto the black of the fender trim (where the tape will be). Clean until the rag contains little or no residue.
Once each fender is clean, you are ready to apply the tape. Tape just above the chrome piece, carefully following the natural curvature of the fender. You will be attaching newspaper later on, so do not press down on all of the tape. Now tape the lower portion of the fender trim. Again, be careful not to cover the chrome piece.
This is the fender trim completely masked, top and bottom, with newspapers in place. Use an old sheet to cover the wheel and tire.
Now you are ready to start sanding. Using the 100-grit paper, sand carefully everywhere on the chrome piece. It is important to get in the small gaps too.
When you are finished sanding, once again wipe clean with Paint Thinner (or similar). Be sure to wipe until the rag is clean again.
Now you are ready to apply the Primer. Spray lightly and in a uniform fashion. This is what the primer will look like, just after being sprayed. Air dry for 15 to 30 minutes depending on the temperature.
Once the primer turns a light gray, you are ready to apply the black paint.
Wait 5 to 10 minutes for the black paint to dry, then apply the clear top coat.
After all 3 sprays have been applied and properly dried, the fender flare should look like this:
Remove all the tape and check out the new look.
View from the back, properly applied and dried.
Here is a view of the rear fender.
Now isn't that better!
Bob_98SR5 is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiTweet this Post!
Yotatech
4WD Truck
Paid Advertisement
Closed Thread
Tags
4runner, black, chrome, depot, diy, home, molding, paint, painted, painting, reflective, spray, trim, wheel, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Adding Rubber Flare Trim - 3rd Gen 4Runner Bob_98SR5 Appearance 0 01-07-2006 09:16 PM
Black 3rd gen 4runner Johnboy Off Topic Talk 2 02-07-2005 03:10 PM
1st gen runner & 2nd gen truck chrome trim removal questions! Ilovemountains 95.5-2004 Tacomas & 96-2002 4Runners 5 10-02-2004 01:52 AM
painting 2nd gen hood hump flat black 934rnr 95.5-2004 Tacomas & 96-2002 4Runners 2 05-05-2004 05:46 AM
Contact Us - YotaTech - Archive - Top
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
2010 InternetBrands, Inc.
