Garmin V Mount Adapter - 2nd Gen 4Runner - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Tech Write-Ups (Staging Area & More Articles In The Wiki) > Appearance
Welcome to Yotatech!
Welcome to Yotatech,
Closed Thread
Old 01-08-2006, 06:41 PM   #1 (permalink)
This is what I started out with, The wood cutout is 1/8" plywood and the epoxy was one of those "epoxy in a tube" kits ( I used a marine grade because of a 15 minute dry time
Here to protect the dash I wrapped it all in saran wrap. ( I also put a piece of aluminum foil in between where the epoxy was to be placed (for heat dissipation)
This is the epoxy shaped to the dash and leveled using the "bulls-eye" level. I carefully lifted it off the dash along with the saran wrap to keep the heat from the dash
Here is a test fit after sanding the edges smooth, Once I knew it was going to fit and be level, I gave it a coat of primer and satin black spray paint
This is a shot of the base attached to the freshly painted base all ready to mount to the dash
Here is what it looks like all togather. In hindsight, I would of moved it to the right about 6".. But what is done is done.
I decided later to mold a groove in the bottom and drill a hole thru the dash for the cable to be fed thru the dash and to be hard wired.. This was a major step and the dash is never to be the same.. But if I did ever take it off, I figured I would put a piece of Velcro there like a radar detector should mount there and you will never see the hole.. I have no plans on removing the GPS.. To date I have logged over 35 thousand miles with my Garmin V and it is still amazing. I highly recommend buying the V over the lower priced models.
Bob_98SR5 is offline
Closed Thread
Tags
2002, 2003, 2005, 2nd, 4runner, adapter, garmin, gen, gps, mount, mounting, mounts, spare, tire, toyota, vmount
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
2nd gen 4Runner Powertank mount pics abalagtas 86-95 Trucks & 4Runners 0 01-23-2006 11:07 PM
Front Mount Trailer Hitch Spare Tire Adapter 4Peanut 95.5-2004 Tacomas & 96-2002 4Runners 11 06-15-2005 01:45 PM
Garmin IQUE 3600 Mount vlibo GPS & Communication 3 01-28-2005 12:00 PM
Length of 2nd gen. 4Runner Body Mount Bolts? 914runner Offroad Tech 4 08-13-2004 07:28 PM
1st gen 2nd battery where to mount it? wifesaysimadumbass 95.5-2004 Tacomas & 96-2002 4Runners 1 09-26-2003 08:21 AM
2009 InternetBrands, Inc.
