YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Tech Write-Ups (Staging Area, & More Articles In The Wiki) > Appearance
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Closed Thread
Thread Tools Search this Thread Display Modes
Old 01-07-2006, 10:16 PM   #1 (permalink)
Adding Rubber Flare Trim - 3rd Gen 4Runner
By Jalaber
Parts and Tools Needed:
Five (5) Toyota part # 75696-35020 - black self-adhesive flare edge trim padding for the passenger side rear 2000 TRD Tacoma flare.
Alcohol pads
10mm socket
12mm socket
Philips screwdriver
Scissors
I have the Toyota SR5 Factory Fender Flares on my vehicle. They are black unpainted textured plastic. They come as standard equipment on 1999 4Runner SR5 Highlanders. They were available as optional equipment on 1996-1999 4Runners from the factory, and can be purchased from any Toyota dealer for use on 1996-2002 4Runners. Matching end caps and mudguards are availabe for use with and without running boards. Here is a picture showing the flare without trim:
I washed the body and then I removed the flares. I noticed that there was dirt and the rubbing of the fender against the body rubbed off some clear coat
A nice feature about these flares is that they are attached to the vehicle using bolts drilled in the wheel well area. This means they can be removed (which I now do once per year) for cleaning and waxing the body underneath the flares. The larger painted over flares on the 1996-2002 Limiteds and 2000-2002 SR5s are attached using clips through holes that are drilled into the body, making removal difficult at best. A lot of dirt accumulates behind the flares over time. Due to the fact that Toyota delivers these flares without flare trim (otherwise known as a flare gasket, or flare pad), the plastic flare touches the painted body and results in a line of paint being scratched off where contact is made. I noticed my clear coat getting buffed off the first time I decide to remove the flares for a good cleaning, which was when the vehicle was 2 years old.
I have always liked the way the 4Runner Limiteds have a rubber moulding between their painted fender flares and the body. I decided to duplicate this effect on my Toyota SR5 factory black unpainted textured plastic flares. At first I ordered Bushwacker part # 000042-01 which is 30 feet of black self-adhesive flare edge trim used on their aftermarket flares. I did not like this as it is "U" shaped, just like door edge trim. It did not hug the contours of my flares and also looked too thick. Upon further research I noticed the year 2000 Toyota TRD Tacoma has similar unpainted black plastic flares which does have factory flare trim on them. The part # is 75696-35020 which is a 5ft legnth of black rubber padding with self adhesive tape on it. The part number is for the passenger side rear 2000 TRD Tacoma flare.
I ordered five (5) 5ft. pieces which is enough to do all 4 flares, 2 front endcaps and 4 mud guards. Installation is simple. Start of by removing the flares using a 10mm socket. The piece attached directly to the rear doors are removed with a philips screwdriver. To remove the front end caps use a 12mm socket. Clean all removed items with soap and water, then dry. Swab the area on the backside of the flares where you will put the flare trim using an alchol pad. Cut the flare trim to the legnth of the individual flare section you will work on. Remove a little of the red tape backing at a time and press onto the back of the flare, allowing the flap to cover the front of the flare. Take some time to thouroghly wash and wax the now exposed body sections of the vehicle. Then reinstall flares, boots and/or mud guards.
Here is the final product:
Bob_98SR5 is offline
Sponsored Links
To remove this ad, register today!
Closed Thread
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
3rd Gen 4runner/Taco Front Suspension Top Plate and rubber washer Mojo_Risin Items Wanted 1 01-01-2007 08:24 PM
WTB: 3rd Gen 4runner Rubber Cargo Mat TxDox21 Items Wanted 0 03-06-2006 10:27 PM
Adding Extra Accessory Outlets - 3rd Gen 4Runner Bob_98SR5 Electrical 0 12-31-2005 08:23 PM
3rd gen 4Runner - best rubber mats? paddlenbike 95.5-2004 Tacomas & 96-2002 4Runners 20 07-15-2005 09:59 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
