Remote Programming for 99, 00, 01, 02 - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Electronics > Alarm Systems
Welcome to Yotatech!
Welcome to Yotatech,
Old 12-18-2005, 05:59 AM   #1 (permalink)
dgold's Avatar
Post Remote Programming for 99, 00, 01, 02
I looked all over YotaTech for these instructions, but couldn't find them. Below are the programming instructions for the three button remote that came after 1998.
NoliWan posted this on the toyota-4runner.org website. Many thanks go to him! I tried it last night, and -- after a few unsuccessful attempts, it DID work.
I'm re-posting it here, hopefully it will help someone else too. -DG
1. Start with the following conditions: you are in the vehicle
a. Key is out of the ignition
b. Drive door is open ( all other doors are closed)
c. Driver door is unlocked (other door locks don't matter)
2. Insert the key into the ignition (don't turn it) and pull it out.
3. Perform these steps within 40 seconds:
a. Cycle the power locks 5 times. Use an even pace and try
to go relatively fast.
b. Close, then open the drivers door.
4. Perform these steps within 40 seconds:
a. Cycle the power locks 5 times (same as before).
b. Turn the ignition to ON then back to OFF.
c. Turn the ignition to ON then back to OFF.
d. Remove the key from the ignition.
5. Within 3 seconds, the power door locks should cycle (automatically)
indicating successful entry into programming mode. Return to step 1
if the locks do not cycle at this point.
6. Perform these steps within 40 seconds:
a. Press the LOCK and UNLOCK buttons on the transmitter
simultaneously for 1 second.
b. Immediately after letting go of the lock and unlock buttons,
press the lock button by itself and hold for 2 seconds.
Within 3 seconds, the door locks should cycle ( LOCK then
UNLOCK) once-- indicating successful programming. If
the door locks don't cycle, or cycle twice. Repeat steps
6a and 6b--this remote has not been accepted.
c. Repeat steps 6a and 6b for EACH transmitter that will
operate the vehicle. Including any old transmitters.
7. Close the driver door.
dgold is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
00-02 4runner heated mirror retrofited to a 01-04 Tacoma? Tatunka 95.5-2004 Tacomas & 96-2002 4Runners 4 02-16-2009 07:00 PM
rear driveshaft 4x4 measurements 96-00 and 01-02 lenghts neliconcept 95.5-2004 Tacomas & 96-2002 4Runners 3 05-25-2007 04:47 PM
Street Scene grilles: '99-'00, '01-'02 ManyMods 95.5-2004 Tacomas & 96-2002 4Runners 69 04-23-2006 10:46 PM
01-02 4runner climmate control compatible with 99-00? tv4184 95.5-2004 Tacomas & 96-2002 4Runners 12 05-06-2005 12:24 AM
any difference in 99-00 and 01-02 4runner emblems? gn86r 95.5-2004 Tacomas & 96-2002 4Runners 4 12-08-2003 10:11 PM
2009 InternetBrands, Inc.
