Power Lock Antitheft - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Electronics > Alarm Systems
Welcome to Yotatech!
Welcome to Yotatech,
Old 04-17-2008, 02:38 PM   #1 (permalink)
Squiddy's Avatar
OK, so I am thinking about getting a PowerLock system (http://www.powerlock.com/). Seems like good device, but paucity of reviews...(and solidly white trash advertising)
Has anyone had one installed? What's your experience been?
Thanks!
PS Don't leave the "nothing can prevent your rig from getting stolen" comments...I know already!
Squiddy is offline
Old 04-17-2008, 02:55 PM   #2 (permalink)
Elvota's Avatar
Why not just install a fuel pump cutoff switch in a hidden location?
If you are worried about a hotwire theft... that would prevent it... and be simpler, cheaper.
__________________
1990 4Runner | V6 3.4 | 5spd | 240 someoddthousand miles | SR5 | SAS | RLS | 35's | ARB | TJM | 217 to 1 | W8000
- four wheels | three sticks | two hands | one trail -
visit the sticki chronicles
Elvota is offline
Old 04-17-2008, 03:08 PM   #3 (permalink)
Squiddy's Avatar
Not a bad idea of course but aside from being tired of wiring stuff in my truck, I would get no insurance discount, which here in NE is no small consideration. Plus using the switch each time is a bit of a pain. Tho I'll check it out, so Thanks ... any special link you think is best?
Squiddy is offline
Old 04-17-2008, 03:36 PM   #4 (permalink)
Elvota's Avatar
Quote:
Link... as in writeup? I do not know of any off the top of my head. But basically you just have to interrupt the fuel pump circuit with a switch hidden in your cab.
I have a FP switch in mine. It's pretty easy to use... doesn't add that much hassle. I have had issues with alarm systems in vehicles I bought in the past going bad, and not even allowing me to start the car. To me, all the complexity of the PowerLock could lead to trouble down the line, especially if you are exposing the system to a lot of dirt or mud on the trails.
But if the PowerLock gives you some kind of insurance break, that may be worth the additional costs.
__________________
Elvota is offline
Old 04-18-2008, 09:04 AM   #5 (permalink)
eric-the-red's Avatar
You can wire in a fuel cutoff switch so it automatically cuts the power to the pump every time you turn the vehicle off, that's more convenient than setting it each time, or forgetting it each time as I tended to do. You just put a normally open relay in the circuit, with a hidden momentary contact switch to close it. Then connect the relay output to the coil input to keep it closed as long as it has power. As soon as the power is interupted the relay opens again, and cuts off the pump.
eric-the-red is offline
Old 04-18-2008, 10:34 AM   #6 (permalink)
Elvota's Avatar
Quote:
Sounds like a good and convenient idea.. but if the car was hot wired at the ignition switch, wouldn't your relay also be activated? I wouldn't mind simplifying my system as you did, but would like to make it as difficult for a thief as possible.
__________________
Elvota is offline
Old 04-18-2008, 10:38 AM   #7 (permalink)
Quote:
No, the relay doesn't get activated until you push the magic switch, which can be hidden or disguised.
Tags
4runner, anti, cutoff, fuse, lock, openrelay, power, switch, theft, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Power Window/Power Lock Fuse GOH10 Runner 95.5-2004 Tacomas & 96-2002 4Runners 4 12-16-2007 01:26 PM
power lock problem BUZY Newbie Tech Section 4 04-12-2007 09:19 PM
Power locks won't lock kpeckett 95.5-2004 Tacomas & 96-2002 4Runners 6 06-10-2004 02:11 PM
Power Lock motors? Flygtenstein 95.5-2004 Tacomas & 96-2002 4Runners 0 10-07-2003 03:37 PM
Power Lock Weirdness Skydigger 95.5-2004 Tacomas & 96-2002 4Runners 2 01-20-2003 03:09 PM
2009 InternetBrands, Inc.
