Ignition cutoff not working. - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Electronics > Alarm Systems
Welcome to Yotatech!
Welcome to Yotatech,
Old 04-26-2006, 09:54 AM   #1 (permalink)
deathrunner's Avatar
OK, I have installed a couple of alrams before, but this one is driving me nuts.
I have everything working, except the ignition cutoff.
It has a relay that is hooked to a socket that is prewired. The two thick lines were used to splice into the starter/ignition wire.
The other pins have an orange wire and a yellow wire that go back to the unit. No problem there.
Here's where I think my problem is. The yellow wire also has anotehr yellow wire coming off of it. The vague instructions say to wire it to ACC (I/O +), I assume this means the accesory on the ignition harness, so I put it there.
The ignition does not get cutoff when I arm the alarm. I can start it no problem. If I remove the relay, the car does not start of course. I tried a relay that I know works and it still would not cut it off.
So, I tried disconnecting the yellow wire form the ACC, didn't seem to make a difference either way.
Any suggestions on what to try or where to hook that yellow wire to?
__________________
IFS IS FOR LOSERS
deathrunner is offline
Old 05-01-2006, 10:49 PM   #2 (permalink)
bigacuralvr's Avatar
Send a message via AIM to bigacuralvr Send a message via Yahoo to bigacuralvr
Ok, I take it this is a Viper/Clifford/DEI alarm. Here is the thing, the green and black wires go on either side of the starter wire. You have to cut the starter wire in half, the green goes to key side, and the black to starter side. The yellow then gets attached to the IGN (+) wire. Then, your starter disable will work. If you just splice into the starter wire, there is nothing to go into and out of the relay. If this makes sense....awesome!! If not, just PM me, and I'll explain more.
Brett
__________________
Current:
94 4Runner SR5 3.Slow...for now.
SOLD. :(
99 4Runner Limited SuperCharged, Hood Scoop, Westin Bull Bar, PIAA 510's, PIAA GTX Heads and Fogs, ProComp 1069's, True Flow Intake, Jardine Exhaust, Red Interior Lights, Other Little Stuff...
bigacuralvr is offline
Old 05-12-2006, 12:53 PM   #3 (permalink)
Alarm companies are sloppy amateur at documenting.
There are 2 two types of alarm connections: CUT and 'T' TAP. Most connections are 'T' tapped to vehicle wiring. Ignition wires are 'T' TAP to vehicle IGnition, ACCessory, Constant 12v. The STarter (ignition) wires are CUT, so 2 wires, one to starter side and one to key side. That way, starter is disabled when armed.
Those are the connections. Now DMM meter test the voltages.
The IGnition is generally NOT cutoff, unless you custom CUT ignition for added security.
The STarter usually IS cutoff, CUT, disabled with relay.
Brain -> relay -> 12V constant -> T-TAP -> enables IGnition
Brain -> relay -> CUT -> disables STarter
Brain -> relay -> 12V constant -> T-TAP -> enables STarter (for remote start)
That's what it looks like. :-)
B_Sharp is offline
Old 05-12-2006, 09:01 PM   #4 (permalink)
NO worries. I fixed her all up. Thanks, though.
__________________
IFS IS FOR LOSERS
Tags
acc, alarm, car, cut, cutoff, disable, ignition, manual, splice, starter, switch, tap, vehicle, wire, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
oil pressure fuel cutoff switch wiring?? deserttoy84 84-85 Trucks & 4Runners 1 04-05-2007 07:44 PM
Cold start injector cutoff temp on 3.0? suprathepeg 86-95 Trucks & 4Runners 0 10-17-2006 08:52 AM
dealer installed alarm ignition starter cutoff problems KyleT 95.5-2004 Tacomas & 96-2002 4Runners 6 02-21-2006 10:33 AM
new ignition justpassinbye Maintenance & Repair Archives 4 09-01-2005 01:33 PM
Cutoff Lower Bed Half jimbo74 The Fab Shop 13 05-13-2005 08:09 AM
2009 InternetBrands, Inc.
