Door unlock but won't lock with remote - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Electronics > Alarm Systems
Sign in using an external account
Register Forgot Password?
Alarm Systems Discussion related to installation, diagnostics, and purchasing of alarm systems
Welcome to Yotatech!
Welcome to Yotatech,
LinkBack Thread Tools Search this Thread
Old 01-18-2012, 04:50 PM   #1 (permalink)
Personal Sales Rating: (4)
5 Year Member
cchinny's Avatar
So I hit the lock button and the car alarm has along has a long beep until I hit the unlock button. The doors do unlock with the remote, but again won't lock. The doors do lock with the key and the toggle button on the drivers door. Any help appreciated.
__________________
1998 4runner V6 5spd
1999 4runner 3.4 auto
2001 Tacoma Plow truck
cchinny is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiTweet this Post!
Old 01-18-2012, 05:01 PM   #2 (permalink)
Zim
Personal Sales Rating: (0)
Zim's Avatar
Door lock actuator? I have heard of a door lock actuator or latch assembly going bad causing that type of problem.
Zim is offline
Old 01-19-2012, 06:45 AM   #3 (permalink)
5 Year Member
Threadstarter [OP]
cchinny's Avatar
I thought it might be, but it the locks all unlock and lock with the window controls and they all unlcock with the remote. I would think with the actuator it would not work with any. I would think someone would have this problem with the continuous beep when I try to lock the car, but no locking of the doors with the remote. Thanks!
__________________
cchinny is offline
Old 01-20-2012, 11:17 PM   #4 (permalink)
radrace2001's Avatar
i looks like it is seeing a door is not closed. check your door switches they should be on the body. if one is bad the remote will not lock and have a long beep and the window switch door lock will work.
radrace2001 is offline
Old 01-26-2012, 07:06 AM   #5 (permalink)
Quote:
What year of vehicle is this on?
93NMyota is offline
Old 01-26-2012, 05:38 PM   #6 (permalink)
5 Year Member
Threadstarter [OP]
cchinny's Avatar
It is a 1999
__________________
cchinny is offline
Old 01-26-2012, 06:32 PM   #7 (permalink)
tacoma or 4runner? I can help you diagnose no problem i just need to know exactly what kind of vehicle you working with. Also what kind of alarm system? If it works with the door lock button and the alarm confirms your pressing the lock with audible feedback then its gonna be a connection.
93NMyota is offline
Old 01-27-2012, 05:14 AM   #8 (permalink)
5 Year Member
Threadstarter [OP]
cchinny's Avatar
It is a 99 4runner SR5 with the stock remote/alarm system
__________________
cchinny is offline
Old 02-02-2012, 03:15 PM   #9 (permalink)
The long beep on lock from the factory remote means that it's seeing a door open and won't lock the doors so that you don't accidentally lock your remote and keys in the car. Since I'm not at work, I can't look up what the wire colors are and where the door pin switches are. Do you know if it's just the factory keyless set-up or does it have the dealer-installed keyless upgrade system? You can tell if you have the keyless upgrade system if you have that combination led/valet switch mounted in one of the knock-outs on the dash to the left of the steering column.
There are ways to use a process of elimination to figure out which door pin is bad and causing the keyless entry system to see an open door.
AreOhhEnn is offline
Yotatech
4WD Truck
Paid Advertisement
Tags
2000, 4runner, alarm, beep, car, door, doors, lock, locks, long, making, remote, system, tacoma, toyota, unlock, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Contact Us - YotaTech - Archive - Top
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
2010 InternetBrands, Inc.
