YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Electronics > Alarm Systems
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 05-22-2008, 03:24 PM   #1 (permalink)
Team420's Avatar
Alarm stopped working
yup, after flooding my truck the alarm went off till the batt died, and now, the light does nothing, and the remote wont lock/unlock the doors, the black box under the drivers seat was submerged(see avatar) and this wasnt the first time, all previous time it did not go off till it drained my batt though.
I know its a reach, but is it possible that its just disabled, and if so how do I enable it, the truck starts fine, unless I disconnect the black box, and the ignition was changed a before I bought the truck....so i have no door key.
Thanks for any input
__________________
Quote:
Originally Posted by wheelaholic View Post
yea some people get the jeep thing to but i think they make a pill for that
Quote:
Originally Posted by owndog12 View Post
They do it's called a toy pill ! Take two and trade your jeep for a yota in the morning !
93 Runner, 3vze, auto, 4.88 gears, 31" tires, mostly stock, 255k and counting
DD:
94 runner, 3vze, geared 4.56, m/t, 31/10.5/15, only 200k on the clock
Project:
91 p/u, 3vze, m/t, 2" body lift, 4.10 gears, 33's, 219k on the clock.
It's becoming an addiction.
Team420 is offline
Sponsored Links
To remove this ad, register today!
Old 06-30-2008, 06:27 PM   #2 (permalink)
Team420's Avatar
Bump...still cant figure this out. I'm half expecting it to just start working someday, and lock the doors, or worse, not allow me to start it.
It is a fujitsu ten alarm, and nothing has changed, truck starts fine everytime, and still no remote lock or alarm. I know nothing about these systems, so big question is...am I worried for nothing, or will this bite me later?Any advice would be great.
__________________
DD:
Project:
Team420 is offline
Old 07-01-2008, 06:49 PM   #3 (permalink)
fujitsu ten is eclipse. so it is or at least was a good alarm most likely, if it was submerged in water chances are it is done. if not i have no idea how. do you know where the brain for the alarm is located? it is most likely under your dash near the steering column or in the drivers side kick. anyhow if you know where it is check the inline fuses with the alarm, you may have gotten lucky and just popped a fuse. but your safest bet if you find the brain is to just unplug it and remove it. the last thing you want is to replace a fuse and it work for a little while but short out later on down the road from corrosion or water damage.
good luck
jason
drpdmazda is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Speedometer stopped working minidisc8 86-95 Trucks & 4Runners 15 05-13-2008 12:04 PM
'97 4Runner factory alarm/keyless entry stopped working 97t4runner 95.5-2004 Tacomas & 96-2002 4Runners 7 09-07-2007 10:25 AM
'97 Toyota 4Runner factoyr alarm/keyless entry stopped working 97t4runner 95.5-2004 Tacomas & 96-2002 4Runners 1 08-29-2007 12:56 PM
'97 Toyota 4Runner alarm/keyless entry stopped working 97t4runner Newbie Tech Section 0 08-27-2007 08:13 PM
hellas stopped working doink 95.5-2004 Tacomas & 96-2002 4Runners 3 04-09-2003 04:26 PM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
