1st Gen Rear Window Controlled by Alarm
Hey Guys,
Been a while. I needed some help. I'm sick of the rear window switch (with key) at the gate and tired of having to turn on the truck to open the window.
I am looking at replacing my alarm with one of the viper switches and they have extra auxilary ports. One even had 5 extra ports!
http://wwv.crutchfield.com/p_6073606...6V.html?tp=149
I noticed Roger Brown's page addresses the relay box behind the driver and figured this would be a critical junction.
Could I use these functions to control the window switch directly or via relays?
I'm guessing that the alarm would trigger two relays (up, and down) to complete the ciruit (I.e. jumper the contacts)
Just curious if anyone had done this successfully and might have some tips.
Big concerns:
Remote control of this feature, up and down preferred.
How long will it "cycle"? I want to make sure it's enough to open or close the window, but not so much that it keeps the circuit open.
Thanks, Seth
Big concerns:
Thanks, Seth
Schematic of First-Gen MoreFunner Rear Window control with added switch for controlling from inside rear deck is below..
Here are my thoughts... To do what you want:
1) Find out which port on alarm turns on when you UNlock. Probably only turns on momentarily.
2) Find out which port on alarm turns on when you Lock. Probably only turns on momentarily.
3) IF ports above only turn on momentarily, you would need 2 Delay-OFF timer relay (pardon terminology- I'm confused myself- but you want a relay that closes its contacts as soon as it sees control power pulse on and off... and keeps contacts closed for the time it takes to roll window up or down.
3) Replace UP contact (of "Added Switch" in schematic) with relay controlled by port from (2 - lock)
4) Replace Down contact with (of "Added Switch" in schematic) with relay controlled by port from (1- UNlock).
When you read up on the alarm system it should tell you whether or not the UP/Lock or Down/Unlock ports stay on for certain amount of time or merely pulses (momentarily on then off).
If on for certain amount of time, compare with how long you have to press up/down switch to completely move window.
IF momentary, delay-off timer relay should be adjustable for amount of time desired.
-Ray
How First-Gen MoreFunner Rear Window Works
I have the viper alarm with add on window control. I love it. Makes life easier as I can hit the aux button and the rear window rolls down. I wired it per the instructions the control box came with. It was so many years ago that this was installed I can't remember how I did it.
06-01-2021 01:51 PM
FS[SouthEast]: Mercury Villager Fan & DCC Fan Controller
coryc85
09-09-2015 06:24 AM
tpd143
07-07-2015 09:06 AM
FS[SouthEast]: 1st Gen 4Runner Slider Window, Driver Side
coryc85
07-06-2015 04:07 AM
