06 Tacoma with aftermarket alarm problems - YotaTech Forums
Go Back   >
Alarm Systems Discussion related to installation, diagnostics, and purchasing of alarm systems
LinkBack Thread Tools Search this Thread
Old 09-07-2011, 08:08 AM   #1
I was looking through the forums for an answer, but couldn't find one, so here goes:
I have an after market alarm (Viper, though I don';t know the model) for my 06 Tacoma. It will not unlock the doors anymore. I will lock, remote start etc. It has been this way for about 7 months, but I finally got a bit frustrated with hitting unlock to turn the alarm off then unlocking the doors with the key.
Previous advice seemed to be replace the batteries, which I have. I have tried the original keyless entry modules, still no go.
What should I be doing? The dealer looked somewhat clueless to it when I asked them a while back.
palkjdg is offline   Reply With Quote
Old 09-07-2011, 10:14 AM   #2
in the drivers side kick panel, the lock wire should be blue with a black stripe, and the unlock should be solid blue. check to make sure the factory plug didnt come loose somehow, as well as check the lock plug on the brain. If it is a viper, the plug should be white with a blue and green wire coming out of them. check those to plugs and see what happens.
or you can just find the lock wires on the vipers brain, and follow them down to the point where they are tied in, check to make sure all connections are solid. does the door lock switch work inside the truck?
J
drpdmazda is offline   Reply With Quote
Old 09-07-2011, 10:23 AM   #3
The lock switches work inside of the truck. So its gotta be loose on the Viper end then, right?
Not much of a gear head, but gonna go fumble around and take a peek regardless.
Old 09-07-2011, 10:50 AM   #4
i would still check the factory plug as well as the viper plug, just to cover all bases. The viper brain will be a black box, that should have several harnesses going to it. most likely it will be somewhere up in the left corner of the underdash tucked away and zip tied to something. another easy way to find it is to just follow the wires that are coming off the ignition harness and they should lead you right to the brain. can you hear the relay clicking when you hit the lock/unlock? that will sometimes also help you locate the location of the brain, just follow the clicking sound.
Old 09-07-2011, 11:21 AM   #5
The only clicking I hear is when I use the vent anymore. I think I have a leaf in the blower, but that a different problem.
I looked under the kick panel and found the blue/green wire (which I assume was from the viper unlock) was severed by the emergency break. Unfortunately, I only found one end of it and don't know where it was severed from. Could you point me where it should be before I try to put them back together?
Old 09-07-2011, 11:26 AM   #6
you are going to have to find the brain then if the lock wires got cut. The door lock plug will be a small white plug with 2 wires, one green and one blue. then just splice them back together, you may want to extend the wires and re route them so that this doesnt happen again. be sure to secure them out of the way of anything that moves, best method is a zip tie. you should be able to hear the door lock relay attempting to lock/unlock when you hit the remote. the rely should be built into the brain so that will hopefully help lead you to where the brain is located. is it a remote start system as well? if so, remote start the truck while you are under the dash and you may also hear that relay clicking from the brain. it will be a faint clicking so be sure its quiet where you are working
Instrument Cluster gary4runner Newbie Tech Section 3 09-24-2015 01:53 AM
Stock Alarm location???? jetspeedz 95.5-2004 Tacomas & 96-2002 4Runners 0 07-13-2015 10:32 PM
Newbie with 02 3.4l Taco AT with shifting issue. Seattle_Sign_Guy 95.5-2004 Tacomas & 96-2002 4Runners 0 07-12-2015 01:38 PM
02 Tacoma temp gauge fluctuating and trans stopped working Poncho0206 95.5-2004 Tacomas & 96-2002 4Runners 3 07-10-2015 07:21 PM
Aftermarket Rear View Camera Recommendations Suprarossa 99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 0 07-06-2015 06:21 AM
Tags
06, aftermarket, alarm, anymore, box, dont, doors, location, main, manuel, prestige, problems, tacoma, troubleshooting, unlock, viper
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
