whats it take to roll a vehicle back on all 4 - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > General Vehicle Related Topics (Non Year Related)
Welcome to Yotatech!
Welcome to Yotatech,
Old 04-25-2007, 09:50 PM   #1 (permalink)
weakyota91's Avatar
my buddy rolled his f250 quad cab 4x4 2 nite and naturally he calls me. I have a 91 toyota 4x4 with a warn 8000 winch. what it take to roll a vehicle back over especially as big as this one? I naturally dont want to burn my winch up but at the same time want to help out my friend. Im not sure of the curb weight of his vehicle but im not lifting it in the air but whats it take to roll it over. How do i tell whats to much for my winch THANKS VERY MUCH GUYS.
__________________
1991 extended cab
3.0 v6
5" trail-gear sas swap
63" chevies in rear
35x12.5 goodyear mtr's
4:88 gears with trutrac front, locked in rear
warn m8000 w/arb front bumper
marlin crawler rear bumper
flowmaster 40 series
weakyota91 is offline
Old 04-25-2007, 09:58 PM   #2 (permalink)
bob200587's Avatar
I'd be willing to bet that that truck weighs 8000 or better. I think the warn 16500 lb winch is reccomended for that size truck.
Is it flopped on it's side or laying on the roof?
I think you could definatley do it if you used a snatch block to double up your cable.
__________________
87 4runner 4x4 SR5 22RE
ARB Bull Bar,
31X10.50 Mastercraft M/T's, Stock 4.10 Gears, Flowmaster Muffler, LCE Header
AISIN Manual Hubs, Marlin Crawler Sliders
190XXX miles
bob200587 is offline
Old 04-25-2007, 10:03 PM   #3 (permalink)
weakyota91's Avatar
Its Just On Its Side Laying Up Agianst A Embankment. If I Use A Snatch Block And Anchor The Back End Of My Truck To A Tree And Use 16000 Lbs Of Pull Power Whats That Gonna Do To My Frame/front Bumper??
__________________
1991 extended cab
3.0 v6
63" chevies in rear
Old 04-25-2007, 10:08 PM   #4 (permalink)
Staff
DeathCougar's Avatar
Send a message via AIM to DeathCougar Send a message via Yahoo to DeathCougar
snatch block it, but be very careful. Be sure you know what your line is rated for. Just because the winch/block will handle double the power, doesn't mean the cable will.
__________________
Tacoma miniheader install kit Now available! Click here for ordering information
Need that hard to find part? Nix99 Used Toyota and Lexus parts!
Quote:
Originally Posted by space-junk View Post
DeathCougar, you know everything!
Quote:
Originally Posted by fustercluck View Post
Now I know DC is a leader.
DeathCougar is offline
Old 04-25-2007, 10:09 PM   #5 (permalink)
bob200587's Avatar
Well, if you're ARB is mounted with all the hardware I don't think it should pose a problem as far as hurting it or the frame.... What I would suggest though, is if you do try to pull it. You will have a hard time pulling it sideways because the tires will just be dragging, not rolling, plus it may be hard to find a suitable spot to hook up to. I'd try pulling from the front or rear at an angle so that it can roll and move out away from the embankment.
I think that the ARB should be really solid....I mean, they put alot of engineering hours into it, so you'd think they would make it to where it would be able to handle some serious loads. And if you have a hitch in the rear, I'd use that to anchor to the tree as it will be centered and put less stress on the rear of the frame.
__________________
ARB Bull Bar,
190XXX miles
Old 04-25-2007, 10:10 PM   #6 (permalink)
Staff
Quote:
as long as you are securely anchored to the frame, it wont hurt anything. You're not dead lifting the entire weight of the truck, just rolling it over on an axis.
Do NOT use the flismy factory front or rear bumpers. You'll pull those right off the truck.
__________________
Old 04-25-2007, 10:15 PM   #7 (permalink)
weakyota91's Avatar
Yea Its A Arb. Well Lol I Have 12 Out Of 16 Bolts The 4 That R Missing Go Into Bottom Of Front Crossmember (where Top Of Skidplate Bolts) So I Think It Will Hold We Will See Im Headed Out There I Will Let U Guys Know Tomorrow What Happens And Take Some Pics If They Show Up.
__________________
1991 extended cab
3.0 v6
63" chevies in rear
Old 04-25-2007, 11:02 PM   #8 (permalink)
Elvota's Avatar
I saw a technique that was a little advanced but simple in concept. Scroll way, way, way down this link to the "Roll-over stiff leg" diagram and instructions. It's almost at the end.
Click me:
The entire article has an amazing amount of info and should more then answer any question you could ever have about line rating, winching, pulling and extraction.
Perhaps this "Stiff Leg" technique will give you the leverage you will need. I have never tried it, but it does seem to make sense and the author obviously has a very thorough understanding of the subject.
Best of luck.
Edit: Make sure you clear the cylinders of oil by removing the spark plugs and firing the motor once you are rubber side down. If you don't, and oil is in there, the engine can hydro lock and cause all sorts of major damage. Be careful and come prepared as oil can shoot a great distance at high velocity. Do you best to keep the mess contained and respect the surrounding area to keep us all wheeling in the future.
__________________
1990 4Runner | V6 3.4 | 5spd | 240 someoddthousand miles | SR5 | SAS | RLS | 35's | ARB | TJM | 217 to 1 | W8000
- four wheels | three sticks | two hands | one trail -
visit the sticki chronicles
Elvota is offline
Old 04-25-2007, 11:30 PM   #9 (permalink)
seanz0rz's Avatar
Send a message via AIM to seanz0rz Send a message via MSN to seanz0rz
truck weighs no more than 7000 pounds.
__________________
1998 Toyota 4Runner SR5 V6 4x4 in Evergreen Pearl Metallic, Sonoran Steel #1, 285/75R16 BFG A/T, Elocker retrofit, Tundra calipers, brembo blanks, hawk lts pads, CarPC in custom center console with molded Indash touchscreen, KC daylighters mounted on Surco Safari rack, Custom sound system, 4xinnovation sliders, sleeping platform, Shrockworks front bumper, 1" 4crawler body lift, etc.
Pictures
Photobucket is being updated, if a picture i posted no longer works, please PM me.
seanz0rz is offline
Old 04-25-2007, 11:42 PM   #10 (permalink)
Kevin286's Avatar
Send a message via AIM to Kevin286
Quote:
Click me:
Best of luck.
X2 on billavista's winching bible.
The short though, if it's on it side you will have no problem flipping it back to all four with your 8k warn. I have the same winch and have flipped back my buddys truck and it took hardy any effort at all. Stand clear, be safe.
__________________
'94 4runner. 3.0, 5 speed. Downey HD Coils, Edelbrock IAS all around, K&N drop in. 31x10.5 BFG. Aisin manuel Hubs, Diff Breather, Removeable doors, ARB Bullbar/Winch combo, OME Torsion Bars.
'83 Toy hilux. .040 over EB 261 DT headers, 35" BFG M/T on MT 15x8. Custom bed. Dual battery setup. Miller Locker rear, 5.29's, 8000m w/masterpull syn. 2" drive train lift 61.5 Deaver rear leafes, rear toy mazda hybrid front, square tube DS, OBA. bla bla bla
Kevin286 is offline
Old 04-26-2007, 05:33 AM   #11 (permalink)
Mark in MD's Avatar
Quote:
Using a snatch block though, the stress on the cable is almost half, since there are essentially two cables.
Click me:
Wow! Great link! THANKS
Mark in MD is offline
Old 04-26-2007, 09:37 PM   #12 (permalink)
weakyota91's Avatar
Well sorry guys i couldnt get any pics. they didnt turn out. everything was to dark. but little yota pulled him back over. streched all but halp of a full wrap of cable out when around a tree using a snatch block and to his truck while anchoring the ass end of myne to a tree and pushed to button took all of 30 seconds and bam his truck was back on all four. I was very surprised it was that easy.
__________________
1991 extended cab
3.0 v6
63" chevies in rear
Old 04-26-2007, 11:29 PM   #13 (permalink)
deserttoy84's Avatar
Send a message via AIM to deserttoy84
should of just left it
__________________
1984 toyota sr5 4x4
22r w/ weber 32/36
Pro comp 4" front springs & 3" rear downey spring
Home made On-board air system
V6 4.88 lock rites F & R
Bilstein 7100 reservoir shocks
deserttoy84 is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Gen1 4Runner Roll Bar - whats the "plate" for? ewong 86-95 Trucks & 4Runners 12 05-30-2007 11:17 AM
Gear grinding noise when vehicle at a standing stall or rolls back Maverick2004 95.5-2004 Tacomas & 96-2002 4Runners 1 06-16-2004 03:28 PM
Whats a Borla cat back worth to you? JDeMello 95.5-2004 Tacomas & 96-2002 4Runners 0 11-16-2003 10:35 PM
2009 InternetBrands, Inc.
