What is wrong with this picture? Aisin Manual Hubs - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > General Vehicle Related Topics (Non Year Related)
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-05-2009, 07:37 PM   #1 (permalink)
Super Moderator-Sponsoring Member
Staff
waskillywabbit's Avatar
Send a message via AIM to waskillywabbit Send a message via MSN to waskillywabbit Send a message via Yahoo to waskillywabbit
Question What is wrong with this picture? Aisin Manual Hubs
waskillywabbit is offline
Old 10-05-2009, 07:39 PM   #2 (permalink)
BigBluePile's Avatar
Send a message via MSN to BigBluePile
Do we win something if we get it right?
__________________
Logan
aka: BBP
Kiss my IFS.
RB4R Life Member #2
THE ULTIMATE TOYOTA RESOURCE
'86 4Runner SR5 22R-E
4" Procomp/Superlift/Rancho 9000x/BudBuilt skids. Downey Header/Magnaflow exhaust, Supra AFM. 315/75R-16 Baja Claws, 4.88's, TrueTrac rear.
Rear disk kit/trans e-brake. Addicted Offroad winch bumper/MM 9000
Current pics
'06 4Runner Sport
270/65R17 BFG All Terrain KO's
Quote:
Originally Posted by Junkers88 View Post
Admit it, you like reading my posts. It reminds you of the days before your runner was the monster that it is now.
BigBluePile is offline
Old 10-05-2009, 07:41 PM   #3 (permalink)
malteserunner's Avatar
The HUGE gap between the face and the body?? Or, are those washers sticking out?
__________________
87 4Runner, 22re, 5 spd, 4.88, ARB rear, Mile Marker PE8000, Downey Header, TG Sliders, 3" BL, Home Fab Front and Rear Bumper, WabFab Bikini Top, Rustoleum OD Green. Build Thread
98 Tacoma Prerunner, 2.7, 340k.
91 4Runner, V6. 5 speed, Pro Comp lift, 33's, Rock Crawlers. Sold.
malteserunner is offline
Old 10-05-2009, 07:43 PM   #4 (permalink)
Staff
Quote:
You get the admiration of Yotatech.
Quote:
Originally Posted by malteserunner View Post
The HUGE gap between the face and the body?? What do I win?
X thanks for playing.
Old 10-05-2009, 07:43 PM   #5 (permalink)
algranger's Avatar
Rotors are screwed up
Floor jack in the gravel?
Bad taste in paint color
ACE hardware bolts
The housing is dented from somebody shooting cone washers across the shop
__________________
I said lie, for me
lying under a process tree
algranger is offline
Old 10-05-2009, 07:46 PM   #6 (permalink)
Ok, I see it now, but I'll let someone else play.
__________________
Old 10-05-2009, 07:46 PM   #7 (permalink)
Staff
ACE hardware bolts
Those are aesthetics. This is a failure if you took this hub offroad...and a quick failure.
Old 10-05-2009, 07:49 PM   #8 (permalink)
warn hub body with Aisin cap?
__________________
Logan
aka: BBP
Kiss my IFS.
RB4R Life Member #2
Current pics
'06 4Runner Sport
Old 10-05-2009, 07:51 PM   #9 (permalink)
crawlerjunkie's Avatar
Is the problem in the hub or rotor?
crawlerjunkie is offline
Old 10-05-2009, 07:54 PM   #10 (permalink)
Staff
This is a stock 84 ext cab front axle. Rotors are probably warped a little but getting replaced.
The glaring issue that is wrong would cause an almost instant failure the first time you took this axle offroad and you would be hitching a ride home. I am fortunate to have found it when I did.
Look close.
Old 10-05-2009, 07:54 PM   #11 (permalink)
theAuthority's Avatar
it's not locked, haha.....
I fail
theAuthority is offline
Old 10-05-2009, 07:57 PM   #12 (permalink)
Stacked washers instead of a cone washer and lock washer?
__________________
Old 10-05-2009, 07:58 PM   #13 (permalink)
Windsor's Avatar
The hub doesn't match the rotor, everything sticks out too far.
edit: er.. the lock doesn't match the hub/rotor.
__________________
'87 T4R Deluxe, mall crawler
every non-SR5 option installed (sans AT), as well as:
* Cruise Control (dealer installed)
* Michelin LTX A/T2 31s on 1st-gen alloy rims
* SmittyBilt granny step bar
* SR5 Instrument Cluster
Windsor is offline
Old 10-05-2009, 07:58 PM   #14 (permalink)
Is there a crack?
__________________
Logan
aka: BBP
Kiss my IFS.
RB4R Life Member #2
Current pics
'06 4Runner Sport
Old 10-05-2009, 08:01 PM   #15 (permalink)
Staff
Very good eye and a proper assumption if you know how hubs go on.
If you look closely at the picture guys you will see that on each hub stud you have a flat washer, a lock washer and a nut. I tried to put on a new set of alloys to test fit them and they would not slide on the wheel hub because of the washers. So I was removing them and lo and behold there were no cone washers on this manual hub holding it on. The PO had put on flat washers over the holes, the lock washer and the nut. If I had taken this truck offroad and tried to lock in the hubs and put them under stress I am pretty sure I would have busted something for sure and been pretty pissed.
As it is I was lucky and found this sooner rather than later. I was planning on rebuilding the whole front axle and upgrading the brakes anyway, just now I am going to do it sooner as there is no telling what other corners were cut and what else has been left off.
Lesson learned. Inspect your truck well before trusting anything the PO tells you.
Old 10-05-2009, 08:03 PM   #16 (permalink)
there's no tire on that there hub.
Old 10-05-2009, 08:05 PM   #17 (permalink)
Windsor's Avatar
swing-and-a-miss.
ah well.
__________________
Windsor is offline
Old 10-05-2009, 08:07 PM   #18 (permalink)
neversieze on the studs, your wheel is going to fall off at he worst time.....going down the road. Do I win?
mistreatedtoys is offline
Old 10-05-2009, 08:14 PM   #19 (permalink)
man I suck at this game...
__________________
Logan
aka: BBP
Kiss my IFS.
RB4R Life Member #2
Current pics
'06 4Runner Sport
Old 10-05-2009, 08:21 PM   #20 (permalink)
camo31"10.50"'s Avatar
looked to me like it has IFS hubs on a SFA lol
i thought the SFA hubs were like..taller (if you got em sittin on a kitchen table) than IFS hubs??
but yes the washer thing would cause a problem..but it wouldnt cause it to fail would it?? as long as everything is nice and tight?
__________________
FOR SALE 1986 Ext. Cab 4x4, rebuilt 22R, 5spd, 31x10.50 X-Terrains FOR SALE
1992 SR5 FO RUNNA V6, 5 speed, 4in. trail-master lift, 33x12.50 BFG muds, 4.56 gears!!! and an IMMACULATE interior..yes..you should be jealous
"Its still a toyota man.. Dont deprive it of its capabilities.."
"If you can read english, Thank a teacher...If you can speak it, Thank a soldier!!" Kelli Ruark-2009
camo31"10.50" is offline
Old 10-05-2009, 08:23 PM   #21 (permalink)
Staff
DeathCougar's Avatar
Send a message via AIM to DeathCougar Send a message via Yahoo to DeathCougar
Dang i was busy watching the 5th element when you posted this!
__________________
Tacoma miniheader install kit Now available! Click here for ordering information
Need that hard to find part? Nix99 Used Toyota and Lexus parts!
Quote:
Originally Posted by space-junk View Post
DeathCougar, you know everything!
Quote:
Originally Posted by fustercluck View Post
Now I know DC is a leader.
DeathCougar is offline
Old 10-05-2009, 08:24 PM   #22 (permalink)
Corbin Dallas Multipass....
__________________
Old 10-05-2009, 08:25 PM   #23 (permalink)
Staff
OH OH MY TURN
X
IFS hubs have a flat dial, SFA hubs have a raised dial.
__________________
Old 10-05-2009, 08:28 PM   #24 (permalink)
AHAHAHHAHAHA!! I peed a little...good one hehehe!
__________________
Logan
aka: BBP
Kiss my IFS.
RB4R Life Member #2
Current pics
'06 4Runner Sport
Old 10-05-2009, 08:30 PM   #25 (permalink)
the hub dials on my '86 are the exact same as the ones on my '80......of course they could've gotten switched around..
dangit though..i was hoping i was right and maybe i could win a sticker or somethin neat like that
__________________
Tags
aisin, hubs, manual, sale
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
