YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Tires & Wheels
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 08-27-2008, 05:20 PM   #1 (permalink)
What is the point of large tires??
Ok seriously....besides the fact that they look good what is the point of having 35s on your truck instead of 31s for example?
I understand tire width helping with the amount of rubber on the road/dirt/rock/mud/whatever you're driving on.
What is the deal about having taller tires though? Is there a benefit?
Quattro15 is offline
Sponsored Links
To remove this ad, register today!
Old 08-27-2008, 05:26 PM   #2 (permalink)
crolison's Avatar
makes breaking easier
Well, larger tires allow fo more ground clearence, you get more surface area when you come upon a object, the bigger rocks become smaller.
There are lots of benefits to them, but you have to have the right set up to go larger.
__________________
97 4runner, 2.7 5speed 4wd, 4.556, 255/85/16 Maxxis Bighorns
rear diff breather, 4 hella 500's driving, sliders, wilderness rack
custom bumper
arb locked rear
toytec adjustables, ome 891's, bilstein 5125
manual hubs
broken front and rear swaybars
My Profile
crolison is offline
Old 08-27-2008, 05:31 PM   #3 (permalink)
96redtoy's Avatar
^ beat me to it
well a taller tire is actaully what gives your truck more ground clearence not the lift, and ground clearence has to do a lot with off road to some extense
also when you are trying to climb over a rock that is 30" tall with say 31" your tire has to climb half way up the rock before you get over it, but when you have a 35" you can almost roll over it instead of climbing first
hard to explain but i think i got it
__________________
96 tacoma stock
2.7L,
5speed,
manual locking hubs,
31x10.50
cobra cb
GO GATORS
Quote:
Originally Posted by Matt16 View Post
If a winch survives being hooked up to a Jeep, it should be more than enough for something that isn't always stuck, half-broken and barely working.
So, you're putting on 37" Iroks and you're worrying about ride quality? That's like a 500lbs chick worrying about one more smarty.
96redtoy is offline
Old 08-27-2008, 05:32 PM   #4 (permalink)
I understand what you're saying....
I was just curious as to the logistics of it all.
Thanks!
Old 08-27-2008, 05:39 PM   #5 (permalink)
4Runner 4Ever's Avatar
Quote:
anyone can have the right set up if they have a sawzall!
jk
__________________
86' 4Runner all stock except for the 34x10.5-15 swampers... =)
Obama-Marx '08...Bringing socialism to the land of the free...
Future Mods:
2" Body Lift/Drivetrain Lift
5.29's & Aussies F/R
4" Procomp/Rancho/Whatever Lift + 63" Chevies in the Rear
38.5X11-15 Boggers while still rockin the IFS!
4Runner 4Ever is offline
Old 08-27-2008, 05:52 PM   #6 (permalink)
ryantowry_81's Avatar
also bigger tires will help in the pressure you put on the ground so in the mud you can float more. also in thje mud the taller tires give you more of the radius of the tire in contact with the dirt thus helping to increase the frictional forces on the dirt and pulling you through the mud better. Wide tires also help with added footprint but the height helps too.
__________________
the "Turtle":
goes really slow but always gets there in the end!
84 ex cab
63" chevies
Rears Up Front
Square Drive Shaft
Trail Gear Cross over
aussie locker
39.5x15-15 TSL's
295k on motor, new Buick V-6 motor on the way!!!
Denali offroad club:
http://www.denalioffroadclub.com/for...orum/index.php
ryantowry_81 is offline
Old 08-27-2008, 05:56 PM   #7 (permalink)
Staff
Lysmachia's Avatar
Send a message via AIM to Lysmachia Send a message via MSN to Lysmachia Send a message via Yahoo to Lysmachia
I have many examples where larger tires would have made a difference... It really does improve ground clearance, but with larger tires you are looking at re-gearing as well as the possibility (yuck) of trailering....
__________________
Molly
aka Lysmachia
93 4 Runner SAS - All Fixed in Junk Yard Goodness
Get your 4x4 VIDEO pr0n here
Lysmachia is offline
Old 08-27-2008, 06:00 PM   #8 (permalink)
So if I have 31s on my truck right now, how large can I go before I'd have to regear regardless of whether I'd have the room for them without mods?
Old 08-27-2008, 06:01 PM   #9 (permalink)
toyota-erik's Avatar
I run big tires because I have a really small penis
__________________
81 Toyota P/U, 22R with GotPropane kit, wheelbase stretched 5", bobbed box, narrowed tube frame from cab back, full exo, tube doors, Warn 9000i, 36" IROKs,TR bead locks, 4 link front, 3 link rear, Fox 2.0 16" all around. Rear axle is shaved, trussed, V6 3rd, CroMo axles, 4.88, full spool, and disc brakes. Front axle is trussed, HP 3rd, 4.88, 30spline Longfields, and a lunchbox locker. Full hydro Howe desert series race pump(reworked by PSC), CroMo steering arms, 4.7:1 t-case
toyota-erik is offline
Old 08-27-2008, 06:02 PM   #10 (permalink)
Staff
Lysmachia's Avatar
Maybe 33's. What do you have (rig wise) because engine power will help/hurt in that decision. For example, ~TC~ definitally needed to regear to 4.88's when he went to 33's but that's cuz he has a 3.slow....
__________________
Molly
aka Lysmachia
Old 08-27-2008, 06:03 PM   #11 (permalink)
Staff
Lysmachia's Avatar
Quote:
And I run Big tires because I have small Boobies...
__________________
Molly
aka Lysmachia
Old 08-27-2008, 06:15 PM   #12 (permalink)
JasonWin's Avatar
That's a sig worthy quote if I ever saw one!
Anyway allthought it's been said already taller tires means more clearence. Wider tires make it easier to "float" of stuff like mud sand and deep snow. Snow on the roads however you probably want a tall but skinny tire.
__________________
Weekend Rig - 85 SR5 Pickup:
4x4, 5-Speed, 22RE
Custom built box with big stepside fenders
31" ETS Trail Masters
About 3" body lift
Pioneer CD player (iPod Controll) with 10" sub woofer
JasonWin is online now
Old 08-27-2008, 06:40 PM   #13 (permalink)
I have a 99 Tacoma with 3.4 V6 in it. TRD and Towing package if that makes a difference.
I'm going to be getting the Sonoran Steel lift kit for it and upgrading to 16 inch wheels for the Tundra brake upgrade as well.
I'm just wondering what size tires I should run if I raise my truck up 2 or 3 inches higher then where it stands right now.
Old 08-27-2008, 06:48 PM   #14 (permalink)
Jay351's Avatar
Send a message via MSN to Jay351
You will probibly only be able to run a 32x11.50 (do they make skinny 32's?) without doing some trimming/lifting.
Your 3.4L will be able to cope with the bigger tires, but down the line re-gearing is the best option.
__________________
91 Pickup - xcab - 5sp - 3.0 - sr5 - 4x4 - 230,000kms |2.25" catback w/ magnaflow cat + glasspack | Weasy2k cams | Aisin manual hubs |Diff breather mod | Marlin HD clutch |3" BL | es3000's |2" AAL |1.5" bj spacers | ISR | Alpine headunit | 4" Infinity fronts/5" rears | 4.88's |Rear lockright | 33x12.50" BFG M/T on 15x8" steelies |Hella 500's |4" reverse lights| Grant GT |Downey idler arm brace|hella E-codes| Marlin armor | %100 Amsoil synthetic
http://www.cardomain.com/ride/2572486
Jay351 is offline
Old 08-27-2008, 06:59 PM   #15 (permalink)
Will those fit under my flares??
I ask this because I don't care for the look of tires that stick out from underneath the truck. Right now I'm running 31x10.5 on 15 inch wheels. I'd like a tire that still fits under the flare, the tread I mean...I don't really care if the sidewall bulges out past them.
I hope you understand what I'm trying to say?
Old 08-27-2008, 07:14 PM   #16 (permalink)
Staff
Lysmachia's Avatar
I understand... and if you want to wheel, you'll have to trim. See, a street ready rig with 32's or 33's (I vote 33's) will rub like a well a fat guy in corduroy's! (I know normally it is a fat biatch but since I am a lone chick....)
So if you don't wheel aggressively well it will work. If not, get ready for some rubbage
__________________
Molly
aka Lysmachia
Old 08-27-2008, 07:27 PM   #17 (permalink)
111db's Avatar
Send a message via MSN to 111db
I'm actually having a rubbage sale right now.
Molly you're crackin' me up. Fat guy/corduroys. Speaking of which I can't fit in mine anymore. Guess you won't hear me coming.
Quat you could consider the 255 option like SOAZtim is using, they're about 32.5 diameter (maybe 33) but thinner than a 285. They wouldn't stick out any further than your stockers, but will help with ground clearance.
__________________
Jon
97 4Runner 3.4 * 4.88's * ARB Lockers F/R * ARB compressor * Sonoran Steel numba 1 * 285 BFG AT/KO * TJM 17 * BudBuilt Skids * Stubbs Sliders & BBQ sauce * Irbis out back * Various Electronic Gadgets
111db is offline
Old 08-27-2008, 07:41 PM   #18 (permalink)
86tuning's Avatar
265-70-16 is a 32x10.5x16. Well, 31.5 is the actual OD in most cases.
__________________
- Brian
86tuning is offline
Old 08-27-2008, 07:51 PM   #19 (permalink)
xcmountain80's Avatar
Before you going quoting the calculations just look on the manufactures site and look for the specs there. I'll save the rant but a 285/75/16 Interco SSR is 33.9 X 11.5ish where a typical 285/75/16 is 32.9 X 10.9ish so just cause it says it's a certain size doesn't mean it is. That being said I think sonoran has a VIN gear code link on his site. I thought and please correct me if I'm wrong whehter you have small appendages or not Taco's typically come with 4:30's and 4RUnners with 4:10's. You should be fine up to 33's and would have to trim less than us 4Runner owners because the taco's fender wells are a bit higher than ours.
Aaron
__________________
02 4Runner, BudBuilt Skids, Custom Sliders, 1"+/- wheel spacers, Nitto 295's, Painted Limited Wheels, TJM-17, ARB-Taco BullBar, LightForce 240's, 1st Gen rollbar, Engel 45 with custom slide, SS 3" Lift, WabFab 1" BL, SS limit Straps, Viair 450C, Aussie Locker Manual hubs and Tru trac with 4.56, Garmin 276c, Icom V8000, Cobra 75, Hannibal RTT, Shady Boy Awning, Tru Speed calibrator, T-Max 9k, 100' MP syn line. Nitto 295's
xcmountain80 is offline
Old 08-27-2008, 08:00 PM   #20 (permalink)
